Camber shims....
They work great - that is all
One of the best mods I've done to the car - can't believe how much cornering grip I have even on boost
Just took my brother in law out in it and he can't believe how fast the Cossie is and I'm not even running full boost. Think he is gonna sell his 997 2s soon and look for a turbo version lol
I was going to fit them until i read the arse end of this thread
http://forum.fordsierraclub.co.uk/vi...0475&start=125
It says the camber shims not only change the camber but also affect toe, because the bolt holes are not parallel to the ground. The guy that fitted them and had the alignment checked went from 4 mm toe in to 17 mm toe in, while 3 mm is said to be optimal.
But how much the toe is effected depends on the ride height. The lower you go, the more parallel the shim gets to the ground. When they are fully parallel there is no change to toe when fitting the shims.
I have had the camber shims before, but I removed them again. I now fitted 2x 1mm thick standard shims to the top bolts. After that I had the tracking measured and put some thin shims from Mike R to get the toe setting correct. The shims for the toe need to be very thin, as the toe setting has to be much more accurate than the camber setting. So there is no way of doing it on sight.
I cannot see how fitting that shim in will affect the toe in and out as your not moving the hub that way your only moving the angle it sits against the hub that will affect camber!. Has anyone with these fitted had the tracking checked? and know what there rear wheel toe in is?
The hub (and therefore the shim) is not completely parallel to the ground. If it was parallel to the ground it would not affect toe.
Think of it when you turn the shim 90 degrees, no everything it would normally change in camber is now changed in toe. Having it at 5 or 10 degrees (what it probably is in reality) means both camber and toe are changed.
I'll have mine checked and let everyone know... But mine's a lot more planted now and feel a lot better and tyre wear looks like and is wearing like it uses the whole tyre now.
Depending on the ride height it doesn't have to effect the toe setting in a negative way. You just need to have it checked. There is also no reason why the toe would be perfect without the shims fitted. Lowering also affects the toe (giving more toe in). So if the camber is too negative I would fit them and have the toe checked. Then you can adjust the toe afterwards.
Hi, yep I have been active on there as you say, the thing is to have them checked as I think I said to Matt when he was getting his. They must as said here unless parralel to the ground have an effect on toe ( vary with ride height as standard ) so abit of machine work or mike r shims to get it bang on. There is alot using them and they are feeling the benefits in both grip and tyre wear.
Marc sierra
12
Aug 30, 2015 10:38 AM
track.focus'd
Aug 12, 2015 05:53 PM
xrsi
Nov 14, 2005 10:48 PM
DaveEscos
Oct 29, 2005 12:42 AM
