Gripper Diffs & MOTs
Old May 23, 2012 | 03:51 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Gripper Diffs & MOTs
Well the old banger is due a MOT next week
I have not had a MOT since fitting the Gripper Diff.
Can it be tested on the brake rollers as im sure they turn one wheel backwards and the other forwards when doing the brake test ? I don't want my diff £ucked up.
Any advice ?
Steve
Old May 23, 2012 | 03:58 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Yea, ask the bloke who does your MOT's.
Old May 23, 2012 | 04:00 PM
v man's Avatar
v man
Zee Germans are coming
i will ask my brother for you
he is an mot tester
Old May 23, 2012 | 04:20 PM
saph4be's Avatar
saph4be
Both rollers gossamer way
saph4be's Avatar
saph4be
Goes the same way lol
Old May 23, 2012 | 04:23 PM
scoooby slayer's Avatar
scoooby slayer
lol it goes the same way what on earth made you think that steve lol
DAN-Saff's Avatar
DAN-Saff
I've never had a problem with mine on the brake rollers only issues when they try get it off they normally go pale and ask me to move it about afterwards.
I had one mot test done where they had an above ground 4poster it was wet out and the tester didnt want me to put it on even tho I offered - it spun up an was sideways in the ramp he asked me to move it afterwards and I told him no cos he parked it.
Old May 23, 2012 | 04:25 PM
bigluke200's Avatar
bigluke200
My MOT man carries out a "visual" braking test.
Eg.. Drive across the car park and brake hard.
Not sure how kosher this is but he always asks what kind of diff it is then says "Ahh we best not stick it on the brake test rollers then."
Old May 23, 2012 | 04:26 PM
v man's Avatar
v man
i had an mot tester try and do a brake test on the rollers in my 4x4 saff
just stopped him in time
Old May 23, 2012 | 04:28 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im sure they have a gauge they can use to test the rear brakes on a test drive
Steve
Old May 23, 2012 | 04:31 PM
Rsmat's Avatar
Rsmat
I'd be more bothered about welding than the diff.....
Old May 23, 2012 | 04:34 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Bitchy
Steve
Old May 23, 2012 | 04:38 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
ask for it to be done on a tapping meter thats what i do as its almost a locked diff so i dont wont them damaging it spinning one wheel up at a time i can only imagine the racket it would make trying lol
Old May 23, 2012 | 05:26 PM
Rsmat's Avatar
Rsmat
Originally Posted by cossie4i+
Bitchy
Steve
Sorry mate... It's called ford ownership lol....
Old May 23, 2012 | 06:08 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Actually, a serious post from me for once, are welded diffs ok on brake rollers?
Old May 23, 2012 | 06:17 PM
v man's Avatar
v man
shit the bed its happened
Old May 23, 2012 | 06:18 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Was going to happen sooner or later.
And don't want mr MOT man to stick the s14 on the rollers and something not liking the mig-spec diff lol.
Old May 23, 2012 | 06:25 PM
v man's Avatar
v man
in 4x4 cars they have a thing they put on the floor that reads the braking force
just ask for that to be used cos its got a funky diff fitted
Old May 23, 2012 | 06:30 PM
ajamesc's Avatar
ajamesc
A tapping meter
Old May 23, 2012 | 06:33 PM
v man's Avatar
v man
Originally Posted by ajamesc
A tapping meter
thats the one
Old May 23, 2012 | 06:37 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Hmm, I may just ask for that to be used then!
Old May 23, 2012 | 06:38 PM
studabear's Avatar
studabear
its tapley (its a brand)
there a decelorometer
Old May 23, 2012 | 08:48 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
He needed an excuse to start another "look at me" ASW thread
Old May 23, 2012 | 08:50 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Don't they do one rear wheel at a time, never had mine on the brake roller due to this reason.
Steve
cossie4i+'s Avatar
cossie4i+
TT T38 Power
This is NOT a ASW thread
Steve
Old May 23, 2012 | 09:11 PM
mk2 cossie's Avatar
mk2 cossie
any kind of limited slip diff shouldn't go in the rollers for the brake test, the tapley meter is used instead
Torsen and quaife diffs don't seem to cause any trouble, as they behave like a normal open diff when there isn't any power through them
and a welded diff is a definate no no in the rollers
Old May 24, 2012 | 08:16 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
I'm going to remember this.
Old May 24, 2012 | 08:27 AM
Rax's Avatar
Rax
I'm with mk2 cossie,I didnt think anything with a slip diff should go on rollers for a brake test.The guy who used to do my cosworth used to take it down the road for a brake test.
Old May 24, 2012 | 08:39 AM
RS2000CUSTOM's Avatar
RS2000CUSTOM
As the presenter of a vehicle for MOT it is advisable to make the Tester aware of ANY modifications that you feel may affect the way an MOT is to be carried out.
A welded diff or even a heavily locked diff will certainly require the use of a Decelerometer - which is no hassle or fuss for the MOT station as this is a calibrated and accepted piece of test equipment and is a compulsary item of test equipment to be available to carry out an MOT
There are many types available but this is what they will look like (or similar) usually used for permanent 4 wheel drive vehicles
Old May 24, 2012 | 09:34 AM
DAN-Saff's Avatar
DAN-Saff
I've spoken to Tom Seal@gripper and he has said its not a problem for the mot it's not on the rollers long so the plate wear will be min and when the wheel stops it will engage the diff and lock up but by that point the test would be finished.
A welded diff is different tho.
I've had my diff for over 10years and never had an issue with mots.
Old May 24, 2012 | 09:47 AM
rog's Avatar
rog
I have two diffs in my car, one at the front AND one at the back, will this be ok for an mot?
Old May 24, 2012 | 09:52 AM
grcossie's Avatar
grcossie
It`s not a problem to have 4x4 Cosworths on brake rollers, It`s over in seconds and don`t do harm. We also have a 4x4 program on our rollers
Old May 24, 2012 | 09:54 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Lol @ the rollers going in different directions, where on earth did you get that info from?
Its obviously not just cock you smoke, it must be drugs too.
As RS2000CUSTOM has said, a decelerometer can be used when a car is too low to test or has an LSD, thats what I always get them to do on my cars that have LSDs in them.
rog's Avatar
rog
Lol I was joking sorry.
Car never sees the rollers on my Mot's.
Old May 24, 2012 | 02:00 PM
RS2000CUSTOM
The ATL brake tester I use at one MOT station when I select 4 x 4 mode it does contra rotate the rollers - but this is no good if the 4 x 4 has an LSD diff in the axle/s
As stated before if u concerned about any part of the MOT Regarding your car then bring them to the attention of the tester BEFORE test starts - we do listen sometimes u know lol
Old May 24, 2012 | 04:47 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
This must be what i have seen at the MOT Station i use.
For Chip , it seems you ain't always correct
Steve
Old May 24, 2012 | 06:28 PM
RS2000CUSTOM
This is the one that I use that runs rollers in opposite directions when in 4 x 4 mode
http://www.swge.co.uk/mot_major_test...ake_tester.asp
Old May 30, 2012 | 09:52 AM
cossie legend's Avatar
cossie legend
In northern ireland all cars go down the brake rollers. 4x4 are done 1 wheel at a time. The only car that doesnt have to is one with wire wheels because the rollers will wreck them and they get the tapley meter. welded diff throws the trip on the rollers and is not a tapley meter test its a fail. All cars with lsd are tested on rollers too.
Old May 30, 2012 | 10:51 AM
RigPig's Avatar
RigPig
Steve
Makes a change !!!!!
Old May 30, 2012 | 11:43 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Tapley meter used for test, and it passed
Steve
