044 fuel pump loom, which cable rating to use?
Old May 21, 2012 | 09:42 AM
rog's Avatar
rog
Default 044 fuel pump loom, which cable rating to use?
Ok quick question, I bought a 044 loom from a tuner a while ago (can't remember where) and the wires are too short. Anyway I need to replace the section that goes from the relay to the pump, what sort/size of cable should I use? Bearing in mind I can't seem to get the same size cable locally when I took the small part of the loom into various paces, I think it's 30 amp but not 100% certain. I DON'T want to use stereo amplifier cable so please dont suggest that.
Old May 21, 2012 | 09:57 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
30 amp will be fine
Old May 21, 2012 | 10:10 AM
rog's Avatar
rog
Champion, ta!
Old May 21, 2012 | 12:00 PM
eon51's Avatar
eon51
hi rog burton power do a selection of wire suitable for what u need to do i used the 50 amp rated stuff due to the length it has to go plus useing the thick type cable theres less voltage drop my cossies run fine the last ten years the old cable was getting hot and was brittle hope that helps
mint_s2
Sep 2, 2015 08:58 AM
Ben26
Sep 1, 2015 06:29 AM
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
