What makes coilovers "creak" ?
May 20, 2012 | 03:34 PM
After jacking the car up to clean the wheels yesterday, I noticed the rear coilovers creaking today, what causes this ?
May 20, 2012 | 04:27 PM
Friction between top hat/spring/adjustable platform collars/helpers if fitted.
May 20, 2012 | 05:34 PM
They rubbin on inner edges of body? My ns rear was murder! Binned them for konis.
May 20, 2012 | 05:38 PM
Have ye hammers in scotchland chop
May 21, 2012 | 06:17 AM
Quote:
Originally Posted by
GVK.
Lambchop
Cheers guys,will take a look. Any other ideas ?
May 21, 2012 | 06:25 AM
Rob Virgo
HAHAHA the coilover issue started in England
I just whacked on the brand new konis I had already bought for my saff. I didn't want coilovers
May 21, 2012 | 07:50 AM
Mine was caused by lack of use I think because as soon as I used it a bit more it cleared up. Although maybe the silicone I squirted all over them helped.
May 21, 2012 | 11:39 AM
Good shout mate, will give all the above a go
May 21, 2012 | 12:03 PM
They do normally have the old issue of the spring rubbing on the inner arch on the rear end,
A big hammer sorts it out though.
May 21, 2012 | 12:51 PM
Haha when I 'remodelled' mine for coilover fitting I started off hitting it so gently with a smallish hammer because it felt so horrible.
By the end I was calling it all sorts of names and clubbing it with the biggest b@stard hammer I could find
Does take a bit of effort!
May 21, 2012 | 01:01 PM
Its Recalibrating the shape of the rear inner arch
May 21, 2012 | 01:39 PM
James @ M Developments.
Recalibrating?
So that's the technical term for 'bashing the shit out of'....? Lol
May 21, 2012 | 02:30 PM
May 21, 2012 | 02:36 PM
IIRC the saff had a 6mm build tolerance, so some may need a mod, some may not, some may rub, some may not fit well at all.
6mm is a lot
May 21, 2012 | 04:43 PM
I like that term
I saw someone write on a warranty job card 'torque relaxation' - I asked what it meant, he said 'bolt was loose'
May 21, 2012 | 05:25 PM
KSA-Cossie
fat fookers
jessie_rs
62
Aug 6, 2019 09:27 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
