Gauges. Advice on fittment and makes....
Hi all,
With my 3 door running stage 3 im thinking its time to keep a closer eye on things. I intend to get a 3 gauge holder to replace the centre vents on the dash. Im feeling the 3 most important are boost, oil pressure and AFR.
How difficult/easy are these to fit? Any advice?
Also if anyone has any links or opinions on which gauges are best I'd really appreciate it. Car currently has non and I'd just like to know what is going on.
Thanks.
Thanks.
also intrested,seen alot of stack gauges on this site,Some people mould a pod that looks part of the dash not sure how they do it,also seen the heater 3 pod gauge for the rs turbo on burton Ł40
Yes im looking at the air vent one on burton. Can get it single, double or triple.
I like the look of racetech gauges on there too. Im thinking of getting one of their dual oil press/oil temp gauges. Has both of them in one 52mm display. Then boost and 3rd not 100% sure.
Bump for this guys.
Someone direct me to a decent boost gauge (40psi), oil pressure and afr gauge (although I think afr is already sorted)
Dont want Stupidly expensive ones.
stack for me, i've only two, but will be replacing the other non stack five when i can afford to.
good quality and accurate, far better than the other cheap ones i have fitted, although they do show problems up.
mk3ste
Oct 17, 2021 10:09 AM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
