Is buying this a wise idea?
Been looking for something different and I'm bidding on this, does anyone know anything about them? It's a V8 petrol (i think) snatch landrover, random but at the same time frickin' cool!
It looks like its got the chilli pack on (air con) they also to some pretty good back fires if you turn the ignition off and on! Handle like shit but go quite well all things considered
try looking on www.landyzone.co.uk, plenty of advice, but search first before asking questions as they take no prisoners
Pump the throttle and turn the ignition on and off and it back fires proper well!
Piece of piss to work on as well but handle like a large ferry.
Spent 6 months in Northern Ireland with them.
Wasn't you RLC Carlos? Didn't you drive taverns?
I drove them in Ireland and Iraq and they was fooking redders horrids things in that heat till the aircon spec ones came through, my mate was also killed in one rpg through the a pillar
one lad rolled one and the 2 top cover lads came flying out, one of them shattered his cheek and jaw he'd just turned 18 been out there 3 days.. Good truck though
One bloke in Iraq opened his door and bent down lookin at his map. Driver got out for a piss and left the door open. An RPG went through the cab and brushed against the back of the commanders neck as he was looking at the map and went out the other side!
Fuck all protection against anything other than small arms.
i was mate. We had taverns, saxons and snatch when i was at porta down.
One bloke in iraq opened his door and bent down lookin at his map. Driver got out for a piss and left the door open. An rpg went through the cab and brushed against the back of the commanders neck as he was looking at the map and went out the other side!
Thanks for the input, if i don't get this one i've seen another one I'll have a punt on as well.
