Zetec turbo + escort parts
Old May 17, 2012 | 09:34 PM
roddsescort's Avatar
roddsescort
Default Zetec turbo + escort parts
Right then boys and girls, the time has come.. ive come to the end of the road with this car..
So ill be breaking the whole car..
As it stands...
At the moment it has no interior at all.. but all body panels etc
So Ill start with the zetec turbo parts..
2.0 ltr mondeo silvertop block - about 90k, no damage to the bores. Has had 2 holes tapped in for breather and oil return from turbo.
It is currently in bits, but it will come complete with original crank, pistons and rods with used a.r.p big end bolts, oil pick up and 1.6 escort sump, i can supply used oil pump, water pump, crank pully and fly wheel.
£80? collection only.. or i can bring to santa pod for classic ford
Standard cylinder head which was paired with the above, with standard 2ltr cams
£40 on its own or £20 if bought with the block.. again collection only or can bring to santa pod for classic ford
Area six ported and polished silvertop zetec E cylinder head - not been on the car since re-build - has area 6 zetec turbo spec valve springs in with new valve stem seals
£350 collected - can take to santa pod for classic ford
Garrett T3 turbo with -31 actuator and 360 degree bearing - freshly refurbed by midland turbo's - complete with new gaskets and escort rs turbo manifold - like new!
£350 - collection only or can be taken to classic ford
escort rs turbo exhaust manifold - £30 posted £25 collected
Zetec E cam cover 'DOHC' logo powder coated black - good condition - £30 posted £25 collected
Ford racing Bonnet raisers powder coated black - £22.50 posted £20 collected
Escort rs turbo braided turbo feed £22.50 posted £20 collected
Collins boost gauge 52mm - £35 posted
Auto guages - all brand new in the boxes - come with all wiring and sensors needed £28 posted each
Available - Boost - Coolant temp - Oil temp - Oil pressure
Bailey dump valve - purple - with sfs hose kit in ornage £50 posted £45 collected
Efi inlet sfs silocone pipe for inlet to crossover pipe - brand new in orange jubilee clips
£8 posted
Roose coolant hose kit in silver for mk6 escort - top rad has been cut to allow temp sensor to be fitted - included in the sale £100
Coolant swirl pot, not sure what its off - with a few samco hoses - £22 posted
Guage surround - 3 x 52mm holes with rs logo in corner £15 posted
Bosch/cosworth side-fed injectors from the indy-car programme - flow enough for 320bhp at 4.5 bar fuel pressure on a zetec.. bought from Stu @ grove garage so he will know all about these if you need any more info..
Brand new apart from calibration testing.
£180 posted - £175 collected
Universal intercooler - was off a fiesta rs turbo - about 50/60mm core £50 collected
Escort mk6 Spax rsx coilovers fully adjustable - used but in good working condition with all spanners and adjusters
£250 posted £235 collected
300mm front brake setup - everything needed including calipers, carriers, pads discs, correct bolts and mk1 hoses which havent seen a road mile. Discs and pads are practically brand new.
£120 posted £100 collected
ST170 rear discs set-up calipers, hoses, handbrake cables, discs and pads have seen about 200 road miles, so practically brand new - bearings all ok
£165 Posted £150 collected
Escort front lower strut brace - Was brand new 200 miles ago made by Danzetec as some of you may know - £45 posted - £40 collect
Front gti bumper in amparo blue - good condition - few scratches on n/s front but not too obvious unless pointed out £50 collected
Rear gti bumper in amparo blue - good condition - few light scratches £50 collected
Gti side skirts in amparo blue - have scratches on underside but not visable when on the car - come with 3 jacking point covers - missing n/s front £50
Ill do the whole body kit for £110 if all 3 are bought together!
Rs accessory Front grille from germany - £55 posted £50 collected
Escort boss kit - £25 posted £20 collected
After market leather steering wheel with OMP horn button - £50 posted £45 collected
Fiesta silver/black mp3 alloys - 16's - been painted black, but starting to peel all over so would benifit from refurb - all straight £50 collected
Ford racing escort clock £7.50 posted
Dash surround £10 collected
lights/wiper controls £8 posted
smoked side repeaters - £10 posted
1.8 gti inlet manifold with 2ltr throttle body and 2ltr injectors - £20 collected
Brand new gates zetec timing belt - £15 posted
Zetec turbo block breather blanking plate £8 posted
Standard escort fan £10 collected
Random fans - not sure what there off - £10 each
Fan switches - both have led's when switched on.. £5.00 posted each
Escort rs turbo rear braided brake hoses - brand new £35 delievered
Fiesta mk3.5 subframes - good for fitting aftermarket seats/bucket seats - come with top hats
escort ib5 gearbox from a 1.6 - £25 collected
There are many many many other bits such as..
Starter motor
Alternator
Pas pump
Pas rack
Brand new drop links
All doors - no rust - no inner door cards or speakers - with colour coded handles
All Glass available
Door and boot seals
digital cluster - white dials £20 - around 40k milage
Full wiring loom
Heather box
Mint dash
Steering column
rear beam
front subframes
Pretty much everything on the car..
So if theres anything you need - just let me know
The whole shell is available if anyone wants it.. its got slight corrosion on sills and on o/s rear arch - but apart from that its mint as you can tell from the pictures.. shame to have to scrap it realy!
£300 With all the doors/glass and bonnet
Any other questiuons dont hesitate to ask!
Make me offers, as i need it all gone.. if it doesnt sell, it will be scrapped!
You can reach me on my mobile any time in the day - 07858322822
I WILL be attending classic ford at santa pod so can bring most bits along..
Pictures will follow tomorrow..
Old May 17, 2012 | 11:46 PM
Tweaked's Avatar
Tweaked
Wheels for sale mate?
Old May 18, 2012 | 05:48 AM
roddsescort
Not the mondeo wheels mate, sold them a while back, ive got the fiesta mp3 alloys further down in the thread though
Old May 18, 2012 | 01:00 PM
gup's Avatar
gup
Where abouts are you dude cheers
Old May 18, 2012 | 01:08 PM
roddsescort
Newark, just outside nottingham mate (ng24 3td) i work in lincoln if its any better for anyome
Old May 18, 2012 | 01:23 PM
doga-ot's Avatar
doga-ot
I'll have water temp and oil preasure gauges fella i you can take em to classic ford show?
Cheers Wes
Old May 18, 2012 | 01:29 PM
roddsescort
yea not a problem mate, drop me a pm
Old May 18, 2012 | 01:54 PM
ramgaard's Avatar
ramgaard
Interested in posting to Denmark?
Old May 18, 2012 | 01:59 PM
roddsescort
depends what is is mate, happily if its not something too big like the engine or cylinder head.. what are you intrested in?
Old May 18, 2012 | 02:05 PM
ramgaard's Avatar
ramgaard
Injectors and maybe the front brake setup
Old May 18, 2012 | 02:07 PM
roddsescort
not a problem with the injectors but the brakes im not too sure about, theyll be pretty expensive to post overseas, if you could get some good prices im happy to do it
Old May 18, 2012 | 08:24 PM
ramgaard's Avatar
ramgaard
Okay, i Will Think about the brakes.. Will the injectors fit perfect for silvertop rail and loom?
Old May 18, 2012 | 11:13 PM
roddsescort
yes mate these injectors fit perfectly into zetec fuel rail, and can be used with original wiring/plugs. cheers
Old May 19, 2012 | 06:53 AM
ramgaard's Avatar
ramgaard
Sounds good mate.. Just one of the pieces misssing for my own ZT project. Sad im not living in uk, cause could use the most of it Can you PM for payment details?
Old May 19, 2012 | 07:40 PM
roddsescort
i can mate, pm coming your way!
Old May 19, 2012 | 08:06 PM
ramgaard's Avatar
ramgaard
Awesome mate.. Cheers..
Old May 20, 2012 | 09:15 AM
roddsescort
injectors sold
Old May 21, 2012 | 06:07 PM
roddsescort
swirl pot and bonnet raisers - sold!
Old May 26, 2012 | 11:13 AM
roddsescort
bump - open to offers.. at santa pod tomorrow
Old May 26, 2012 | 11:43 AM
ramgaard's Avatar
ramgaard
Money sent your way matey
Old May 27, 2012 | 07:47 AM
ramgaard's Avatar
ramgaard
Whats up mate?
Old May 27, 2012 | 06:54 PM
nickscunny's Avatar
nickscunny
What size tyres are on the fiesta wheels and what condition are they in?
Old Jun 1, 2012 | 08:43 PM
ramgaard's Avatar
ramgaard
Seen my messages mate?
Old Jun 4, 2012 | 08:34 AM
mk6 gti turbo's Avatar
mk6 gti turbo
Hello mate have you still got the zetec brether blanker and the ford racing clock. Chers
Old Jun 4, 2012 | 08:36 AM
roddsescort
hi mate still got the ford racing clock but the engine and turbo bits are staying for now..
Old Jun 4, 2012 | 03:10 PM
mk6 gti turbo
Ok matedo you no werei can get a breathed blank from?
Old Jun 4, 2012 | 04:06 PM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
hi mate do you still have the bodykit for sale? are they a straight fit on an r reg escort van?
Old Jun 5, 2012 | 08:07 PM
roddsescort
you can get the blanking plate off ebay mate i believe
unfortunetley not mate, the shell is now staying.
Billy_RS
16
Oct 11, 2025 09:41 PM
neil18
Mar 14, 2016 01:08 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
