how to spot a GENUINE ISCV???
Old May 17, 2012 | 02:31 PM
V8ish's Avatar
V8ish
Default how to spot a GENUINE ISCV???
Hi Guys,
My fake ISCV is shite. Is there anyway to tell a genuine one from a fake as I dont want to go down the same route again?
Thanks
Old May 17, 2012 | 09:23 PM
martysmartie's Avatar
martysmartie
I have exactly the same problem , the ones on Ebay are not only aftermarket, but also a different part, that being VAE06 opposed to VAE01 of the standard ISCV.
The way to tell is the genuine one has this written on it, and will be expensive!
By not working do you mean the engine just runs too fast, as this is what happened to me?
James (MSD) gave the game away, it's to do with the spring ratings.
I dismantled both of mine and noticed the genuine one has a stonger bottom spring than the aftermarket one.
Thus the valve opens more=high idle, I tried swapping the springs etc but it was never right, I still have it and may have another look at it at some point.
Martin
Old May 18, 2012 | 06:08 AM
V8ish's Avatar
V8ish
Thanks, I have stretched the bottom spring on mine and it was 10 times better as used to hunt between 500-1600 rpm when cold. Now it on hunts between about 200rpm for a much shorter period but i want to try an cure it compleley . Thanks for the info
Old May 18, 2012 | 08:44 PM
martysmartie
No problem, it is a case of 'trial and error' really.
Martin
Old Feb 14, 2016 | 04:41 PM
Zoggon's Avatar
Zoggon
Hi.
Does anyone know, if there's a difference between VAE01 and VAE06?
Or these are the same?
Old Feb 15, 2016 | 08:02 AM
cossynut2's Avatar
cossynut2
10 Year Member
Buy a new one from a specialist like MSD and you will get the genuine part.Unfortunately the ones which are cheap copies are going to be more trouble than they are worth. Maintaining a Cossy aint cheap! Best of luck.
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mark_
40
Oct 2, 2015 04:40 PM
Sep 28, 2015 10:05 AM
