Ford KA Discuss your Ford KA here!
Resetting Ka Engine Warning Light
Old May 16, 2012 | 02:50 PM
~nomad~'s Avatar
~nomad~
Default Resetting Ka Engine Warning Light
Is this possible without a trip to a garage? Just replaced the coilpack which was the cause of the problem, but the light is still on.
Old May 16, 2012 | 04:04 PM
arse end happy's Avatar
arse end happy
no need a scanner to do it sum faults clear lights wenn fixed but still stored in ecu with no lights on buy a cheep obd reset tool on ebay
Old May 16, 2012 | 09:11 PM
Spax's Avatar
Spax
mine cleared after 5 mins of driving with a new coil pack in
Old May 16, 2012 | 10:20 PM
RichieST's Avatar
RichieST
Disconnecting the negative lead off the battery for half an hour will do it, or after so many engine start cyles it will go off, but the code will still be logged in the ECU and it might stay in limp mode.
Old May 17, 2012 | 11:30 AM
~nomad~'s Avatar
~nomad~
Gonna disconnect battery today and see if that sorts it. Car is driving fine so dont think its in limp mode. Cheers for advice guys
Old May 17, 2012 | 03:12 PM
vaughant's Avatar
vaughant
The kas don't use limp mode,they just drive as normal. I've never got one to clear myself unless via the obd2 port by the passenger/drivers footwell.
Where are you based?if near Swansea I'm happy to reset it for you FOC.
Old Dec 31, 2013 | 10:53 AM
Alexandru Gidali's Avatar
Alexandru Gidali
Dupa alimentarea cu benzina am vrut sa resetez kilometrajul zilnic la zero ,fiind in mers si cu motorul pornit.dupa citeva minute aparatele de bord au luat-o razna,a disparut afisajul electronic al kilometrilor,acul vitezometrului s-a blocat la 30 km/ora,iar acul litrometrului a ramas blocat pe cantitatea din rezervor,situatia mentinindu-se si cu contactul luat si cu motorul in functiune si cu masina in functiune.toate sigurantele fuzibile sunt bune.ford ka,1,3 litri,60 cp,2004 ,motor benzina baa.
Old Dec 31, 2013 | 12:12 PM
RichieST's Avatar
RichieST
Indeed, just what I thought lol
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
