turbo and missfire help needed, :(
ok peeps need ur expert advice if poss??
ive got a 1.8 zetec turbo lump, ive had probs with lack of boost ect we thought was down to a leak in the internal waist gate, well it started boosting propa and was evil even at only standerd boost 6psi, well after about a week started getting smoke coming thru the heaters when came into boost and smoke coming from under bonnet when pulled up at lights ect, what would cause that??? it was supposed to be a fresh reconditioned turbo but wasnt shown any proof when brought it, i know turbo's smoke when on way out but usually from out the bk aint it not from the actual turbo unit?? its even coming out the breather system..... mate thinks it could be a cracked manifold but aint taken it off yet to have a look,
then on the way to the fast show the turbo completly went on me and as soon as it went it started missfiring?? why would the turbo going cause a missfire or have i done some internal damage?? the engine was supposed to be fully rebuilt with all brand new internals but again got no proof to show just what was told off the seller,
if any1 could please give me any kind of info then it would be grateful,
cheeRS
cheeRS
Am sure someone will correct me but if the seals have gone in the turbo and there's excessive blowby into the intake system then that could possibly cause a misfire as it could have fukt the plugs up with oil damage. I'd take it to someone who no's what there doing before you start throwing money at it mate
Do a compression check, sounds like you've cooked your new engine.
If a turbine has broken up you may well have sucked/blown lovely metal bits into your engine. The misfire could well have been caused by a damaged and now non seating valve etc.
Rob,
Rob,
PS the smoke you mention could well be excessive blow by... ie damaged engine etc. Or as mentioned could be down to turbo and damaged oil seals i guess.
How does the engine run generally?
the engine used to run sweet mate, never had any probs with the engine only the turbo, i just really hope aint done any internal damage and is just down to the plugs,
ive got a spare set of plugs so might change them today and if the missfire goes then will mean it was just the oil got into the plugs wont it?
cheers,
muz
Aug 16, 2015 12:57 PM
