idle problem rst s2
Old May 14, 2012 | 06:15 PM
bennyboy1304's Avatar
bennyboy1304
Default idle problem rst s2
hi guys this is realy bugging me and i do not no what it is i was driving down the road 2 days ago and everythink was fine and got back home and the car was idleing at 2700 rpm and holding the revs so i left it and yestoday i went to give it a run and started it and started to creep up the revs agen and holding its bugging me so much coz i do not no what it is i looked for pipes off or leaks didont see nuffink and i put a diffront ecu just to see and the same thing been look and cant see nuffink any ideas much appreciated thanks
Old May 14, 2012 | 10:36 PM
Marc D's Avatar
Marc D
is the throttle sticking open? check again for airleaks. could be a tiny split on one of the pipes
Old May 16, 2012 | 12:48 PM
paul-h's Avatar
paul-h
Vac leaks? Inlet manifold gaskets etc, check everything again.
Old May 16, 2012 | 12:51 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Throttle cable could be jamming open - they can get quite dirty and oily over time and could just not be releasing properly.
Other than that check for leeks as mentioned by everyone else.
Chas
Oct 5, 2015 07:13 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Billy_RS
Sep 13, 2015 04:17 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
