sapp cos wont start
sapp cos wont start
hi guys got a 1990 4x4 with l8 ecu 330 set-up just been restored but fails to start it has no power to the fuel pump and no spark any ideas checked that the wiring to pumps fine and checked pump works with seperate power supply also have a power supply to the coil bit stumped really thought it might have been either the immob or alarm fault but isolated each one and still nothing is there anything in between the ignition and ecu that might stop both items?
On the late 4x4 cosworths there is a fuel cut out switch in the drivers side kick panel
andrewmctiernan
08-09-2015 03:05 PM
