Oil pump removal
Old May 11, 2012 | 08:55 PM
BIL N KEL's Avatar
BIL N KEL
Default Oil pump removal
Can the oil pump on a 2wd saff be removed without removing the engine?
Thanks Billy
Old May 12, 2012 | 09:37 AM
Turbosimpsons's Avatar
Turbosimpsons
i would have thought so, but probably easier to take it out.
Old May 12, 2012 | 10:53 PM
nuttynil's Avatar
nuttynil
RS nutta
Yes it can jack car up disconnect starter take out disconnect steering rack from column undo eng mounts and crossmember drop it down undo sump bolts .dont forget to drain oil and you need a set of spline keys ,new sump gasket and oil pump gasket and o ring for the spray bar.neil
big_Rad
Sep 15, 2017 09:36 AM
YODI
Aug 30, 2015 01:12 PM
Aug 29, 2015 08:16 PM
Adam-M
Aug 26, 2015 05:53 PM
Dubs44
Aug 21, 2015 02:42 PM
