do 90spec's come with a fuel computer?
Old May 10, 2012 | 09:38 PM
andy130's Avatar
andy130
Default do 90spec's come with a fuel computer?
What does the computer do? what is it for? do you need one fitted?
Old May 10, 2012 | 11:34 PM
darrenb16two's Avatar
darrenb16two
Doesn't come with one standard and can't see why you'd want one to be honest
Old May 11, 2012 | 09:27 PM
mentalasanything's Avatar
mentalasanything
It basically beeps a lot and makes out you are driving uneconomically.
Not fitted as standard and certainly not necessary. Although I have one I'm fitting to my cabby.
Lee
Old May 11, 2012 | 09:31 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
optional extra, not hard to fit but you will disconnect it sharpish is you dont keep you tank full
Old May 11, 2012 | 09:39 PM
cossiestu's Avatar
cossiestu
Had one on my second, H reg rst, thought the very late Escorts has them std, to get rid of, as they wernt used on the mk5?
Think, from memory, I 'turned down' my beep with a bit of tape over the speaker hole bit on the back?
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
