oil leak from cam cover
Old May 10, 2012 | 09:23 PM
Harris.'s Avatar
Harris.
Default oil leak from cam cover
I need to have the gasket and half moons replaced, whats the best ones to get and the best way to stop them from leaking
Old May 10, 2012 | 09:43 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
use a very very thin smear of silicone on the head cover and half moons then you will have no leak
Old May 11, 2012 | 05:08 PM
tosh's Avatar
tosh
As above but I also used a cometic gasket and applied Loctite 534 Gasket positioner to both sides of the gasket and have had no leaks for about 7 yrs now.
Old May 11, 2012 | 05:12 PM
cossiestu's Avatar
cossiestu
Can the Cometic one not be used without sealer?
Old May 11, 2012 | 05:20 PM
tosh's Avatar
tosh
Yes it can and is also re-usable but I had a re occurring leak and just wanted to make sure, but by using the Loctite you won't be able to re-use it.
Tarren's Avatar
Tarren
Yes mate you only use a small dab of sealer where the half moons meet the gasket
Old May 11, 2012 | 06:28 PM
Longshanks's Avatar
Longshanks
I bought cometic one from matt Lewis .. Never had a prob .. You will always get good quality gear from matt
dombanks
Sep 21, 2015 08:38 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
rog
Sep 4, 2015 07:24 AM
StephTell
Sep 2, 2015 06:31 PM
