ST170 Sump, why so expensive???
£250 from Ford? Ridiculous, lol.
Seen them on ebay for £25, I take it there cheap copies? Any reason not to get the cheap ones?
Reason for changing, mine is pretty corroded and seeping slightly. Also need to change the hydraulic line between the clutch master and slave cylinders as its bulging. Anyone done this?
Will get the sump from ebay I reckon when im doing the next oil change.
Had to order the pipe from Ford, could only see them for the 1.8's online, and doubt it will be the same as they use a different gearbox.
Used... Im replacing it in case it fails in the future as the current one is bulging, going for a new one.
