Removing old filler
Old May 10, 2012 | 11:26 AM
mattyccfc's Avatar
mattyccfc
Default Removing old filler
Just bought an xr3i. previous owner had used filler to fill a few dings and dents, but didnt go any further. no flatting down, priming, respray etc.
I have know way of knowing how long ago this was done, so is it best to remove, in case the filler has absorbed moisture having been exposed to the elements?
i was hoping that there would be a way to remove the filler without damaging the paint underneath - just in case the dents could be pulled out.
I'm guessing thats out of the question, unless hes used polyfilla!
so will i have to attack it with a a wire brush (circular brush on the end of a drill)?
or can it just be flattened from its current state, then go for a respray?
Old May 10, 2012 | 12:54 PM
whizzisat114's Avatar
whizzisat114
Id take it down to surface to see if its been keed up properly
At least you'll know it's not going to fall out after its painted
Old May 10, 2012 | 12:56 PM
Turbosimpsons's Avatar
Turbosimpsons
grinder with a soft pad and a dust mask.
Old May 10, 2012 | 01:00 PM
whizzisat114
Yeah sorry
Soft linishing disc not a stone grinding disc
Old May 10, 2012 | 01:40 PM
mattyccfc's Avatar
mattyccfc
ok thanks.
so an angle grinder then.
what type of disc/pad do i need? a soft/flexible pad along with sandpaper?
Old May 10, 2012 | 01:44 PM
whizzisat114
Yeah soft disc's
id use the ones that fit in a grinder that have a rubber backing disc.
go for 60 grit discs
Old May 10, 2012 | 01:56 PM
mattyccfc's Avatar
mattyccfc
brilliant - thanks
sandrah01's Avatar
sandrah01
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
