Chip ?
Old 09-05-2012, 08:31 PM
cosworth89
Escort Rs Cosworth
cosworth89's Avatar
Default Chip ?
I have a 1996 escort cosworth small turbo
and i have been told that i can't have a chip?
the car has a GGR T25 turbo,GGR stainless exhaust, uprated fuel pump, K&N induction kit, just wondering what do i have do to see around the 320 horse
any advice is much thanked
Old 10-05-2012, 01:10 PM
cosworth89
Escort Rs Cosworth
cosworth89's Avatar
Please
Old 10-05-2012, 01:22 PM
rog
rog's Avatar
http://www.motorsport-developments.c...ecu_chips.html
Yours will be the EEC IV ECU
Old 11-05-2012, 12:18 PM
martysmartie
martysmartie's Avatar
As said yours is Ford EEC management, this is a limitation in terms of tuning compared to the Weber management of the rest of the family, as obviously is the small turbo.
I don't think it contains an EPROM (Chip) which would explain why you can't do so.
The way the software is usually changed on these ECU's is by plugging in a module into the 'J3' socket.
That, or you would have to "reflash" the internal memory.
I think 320HP is a bit optimistic imo, I think around 300HP is a more genuine figure.
Martin
Old 11-05-2012, 12:54 PM
sailorbob
sailorbob's Avatar
The eprom inside the eec-iv is proprietary to Ford so you cannot get hold of it very easily and it's soldered to the circuit board. Re-flashing is possible but hardly anyone has the kit and knowledge to do it. Luckily it can be easily 'chipped' by means of a J3 chip adapter. Be careful though, some of the chips available are absolute rubbish and you need to find out exactly what they've changed to decide if the vendor's done a reasonable tune.
Old 13-05-2012, 03:57 PM
cosworth89
Escort Rs Cosworth
cosworth89's Avatar
So basically I need a different ecu?
Old 13-05-2012, 08:49 PM
martysmartie
No you can use a module in the 'J3' connector as we mentioned above, the best people to speak to are MSD, mentioned above.
Martin
Old 14-05-2012, 08:29 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
MSD can remap your car, its actually a very good ECU, just not as basic to modify as the earlier ones.
tankybaby66
06-02-2016 02:24 PM
Fiddy
21
29-09-2015 06:10 PM
A.t.p
29-09-2015 05:04 PM
RSmark84
13-09-2015 01:29 PM
Quick Reply: Chip ?
