external wastegate problem FIXED
Old May 8, 2012 | 06:03 PM
s2erst's Avatar
s2erst
Default external wastegate problem FIXED
This is starting to do my head in i finally got my rs all up an running nice an first time out in it since i fitted new turbo an external wastegate problem is its not boosting at all an screamer pipe is open all the time when should be shut till full boost any ideas what ive done wrong cheers just thought does it matter what way round the valve seat goes
Old May 8, 2012 | 07:44 PM
s2erst's Avatar
s2erst
right the valve seat only goes one way so its not that. im not sure if this is right or not but i plug a boost gauge straight off my turbo housing an the gauge didnt even move surly that cant be right its like there is no pressure there hence the top feed to wastegate not being able to keep it shut can anyone clear this up for me cheers
Old May 8, 2012 | 09:55 PM
ghigo's Avatar
ghigo
hello mate,
did u swap the flanges round? was it seating nicely?
Old May 8, 2012 | 10:03 PM
s2erst's Avatar
s2erst
Originally Posted by ghigo
hello mate,
hello mate yeah all done fitted the firing ring only goes one way but stll the same screamer is open all the time
Old May 8, 2012 | 10:09 PM
ghigo's Avatar
ghigo
http://www.tialsport.com/documents/w3_tial_wg_assem.pdf
is the flange damaged from cutting and welding ? cant be seating properly
Old May 8, 2012 | 10:51 PM
s2erst's Avatar
s2erst
From that picture I've got mine up the other way coz doesn't seem to fit the way in that picture
Old May 9, 2012 | 12:16 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
have you removed the wastegate completely? is it still open
Which way have you plumbed up the vac
Old May 9, 2012 | 12:46 PM
s2erst's Avatar
s2erst
ive got gizzmo boost controller. i have air line from turbo housing to T peice an then splits of to port 1 an bottom of wastegate an then from port 2 straight to top of wastegate
Old May 9, 2012 | 02:41 PM
Jamie_EscortSport
Anything like this?
Old May 9, 2012 | 05:38 PM
s2erst's Avatar
s2erst
Yep that's how mine is set up. i have now fixed problem with screamer pipe being open all time so i no got to give it a test drive tomorrow an see if it boost ok
Old May 9, 2012 | 09:09 PM
ghigo's Avatar
ghigo
cool what was it in the end, anything simple lol
Old May 9, 2012 | 10:22 PM
studabear's Avatar
studabear
You do know it won't build boost up while stationary?
Old May 10, 2012 | 07:34 PM
s2erst's Avatar
s2erst
right well took it for test drive an still not boosting an i put a bolt in top of wastegate to keep it shut an still no boost so its not down to external wastegate what else can it be
Old May 10, 2012 | 08:32 PM
muz's Avatar
muz
Wye Valley Hardcore
Stupid question but is the turbo external wastegate compatable or been modified to work with such?
Old May 10, 2012 | 09:52 PM
s2erst's Avatar
s2erst
i bought turbo second hand it came off a honda it that was running external wastegate aswell so should work ok on mine how could i tell
Old May 10, 2012 | 10:02 PM
DazC's Avatar
DazC
Quick simple test. Pull both vac pipes off the wastegate and take it for a drive. If it boosts let off IMMEDIATELY!!
Old May 10, 2012 | 10:23 PM
s2erst's Avatar
s2erst
if it doesnt then what coz i still dont think it will
Old May 11, 2012 | 08:08 AM
Bomber's Avatar
Bomber
Can you post a pic of the install - so we can see how you've piped everything up and how the wastegate is mounted.
Old May 11, 2012 | 08:20 AM
s2erst's Avatar
s2erst
only thing different is the pipe going form turbo housing to bottom of wastgate so i could rule out boost controller
Old May 11, 2012 | 09:26 AM
Bomber's Avatar
Bomber
Have you actually driven it, as it won't boost without load.
Reading back through, how did you solve the wastegate from being open full time and the screamer barking its nuts off?
Have you checked the spring in the wastegate? You can also check to see whether the wastegate is actuating by hooking a air line onto the bottom port of the wastegate and seeing if the plunger moves.
Also I see a Black ERST over Shoreham - is that yours? Has Red calipers and RS 7 Softlines.
Old May 11, 2012 | 09:47 AM
s2erst's Avatar
s2erst
mine is in southwick outside my work arrow tyres an is black with gold hispec brake an rs7's but not softlines. yes have driven mate. yeah done test on wastegate an opens an shuts as it should.
Old May 11, 2012 | 09:58 AM
Bomber's Avatar
Bomber
Yeah thats it. By the Schooner.
Old May 11, 2012 | 10:01 AM
Bomber's Avatar
Bomber
What spec is the turbo? And what does the Boost gauge read at 1k, 2k, 3k, 4k etc? Does it boost a small amount or always in vacuum?
Old May 11, 2012 | 10:58 AM
s2erst's Avatar
s2erst
Yeah thats mine mate. Its meant to be a gt30 so ive just been told by the person i bought it off. on idal it reads -10 an when i drive it then goes to 0 sometimes 0.01/2/3 thats all i get. ive just taken wastegate off an blanked it an took it for a drive still no different so its not the wastegate which now leaves turbo at fault which cr turbo doesnt think it is or major boost leak which i just done a test an is leaking between throttle body to inlet but still dont think its bad enough to give no boost
Old May 11, 2012 | 11:27 AM
Bomber's Avatar
Bomber
Yikes. Whats the actual spec of the Turbo - what is the A/R on both hot and cold sides and Trim of the wheels? If it's GT spec it'll need water cooling (can't quite see in your pics).
It might be mismatched to your engine spec.
Old May 11, 2012 | 11:30 AM
Bomber's Avatar
Bomber
Oh and do the compressor blades spin round freely?
Old May 11, 2012 | 11:49 AM
s2erst's Avatar
s2erst
some pictures. yes all spins up nice
Old May 11, 2012 | 01:08 PM
Bomber's Avatar
Bomber
No idea - the A/R ratio has been polished off the housing. Are you 100% you have no boost leaks? And how far have you taken it - 5500rpm and still zero (with a decent load an in 3rd gear say)?
Old May 11, 2012 | 02:04 PM
s2erst's Avatar
s2erst
like i say mate i have a boost leak between inlet an throttle body which im sorting now but just dont think its bad enough to show no boost at all
Old May 11, 2012 | 02:29 PM
Canada1's Avatar
Canada1
The Honda guys like turbos to start boosting well after 5000 rpm.
Honda cylinder heads have great flow - but one has to rev very high to take advantage.
I would not be surprised if it will only start boosting at 5000 or even later.
Old May 11, 2012 | 02:47 PM
s2erst's Avatar
s2erst
oh really interesting. what if thats not the case would a blown headgasket stop me from boosting at all
Old May 11, 2012 | 03:00 PM
s2erst's Avatar
s2erst
i have just done compression check an are all about 250 not sure what it should be
Old May 11, 2012 | 03:11 PM
Canada1's Avatar
Canada1
250 psi?
That is extremely high. What compression ratio is the engine supposed to have.
Typical compression check for a turbo engine is about 160 psi.
Old May 11, 2012 | 03:57 PM
s2erst's Avatar
s2erst
250 psi?
yeah 250psi i thought it sounded high dont know what ratio is mate
Old May 11, 2012 | 05:24 PM
muz's Avatar
muz
Wye Valley Hardcore
I wouldn't have thought that would stop it boosting at all. I had a leak once on my TB to inlet and it still boosted like normal. Conor had a massive leak on his inlet to head gasket and it still boosted.
Old May 11, 2012 | 05:43 PM
s2erst's Avatar
s2erst
Its all pointing to turbo to me
Old May 11, 2012 | 06:39 PM
s2erst's Avatar
s2erst
Think i may know what I've done wrong on the turbo exhaust side next to compression wheel is an inch hole an i have not welded it up an think it might be leaking from there does that sound like that's my problem
Old May 11, 2012 | 06:52 PM
Rob_DOHC's Avatar
Rob_DOHC
lol, I think you may have found your problem mate.
Old May 11, 2012 | 07:08 PM
s2erst's Avatar
s2erst
lol i think i may have. Im sorting it tomorrow so will let you know then if it does work is it ok to give you a buzz Rob to sort out setting my boost controller out cheers. Did you still want your door handles done mate
Old May 11, 2012 | 07:40 PM
Rob_DOHC's Avatar
Rob_DOHC
Yea no worries, give me a bell any time you like I'm out at some point looking at a car so if I don't answer just drop me a txt and I'll give you a call back.
