General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
been a while since i worked at renault but seem to remember getting a 3mm drill and there was a small hole in the plate and a wheel with holes in it and you wind it undone to remove the cover
I believe that is on the petrol model where the ecu is attached to the inlet manifold.
Mine is attached to the inner wing behind the battery.
yeh tap it loose with a small punch then turn it back, harness normally chafes on the cage aswell
