crimping tool
Pretty tricky to get one. I have a CAT issue jobby or two ($700)
I noticed a few on EBay.COM. Shipping would be tricky
IDE pop one in the post if I wasn't state side.
A few on eBay USA.
The only one worth owning.
http://www.ebay.com/itm/Harley-OEM-D...#ht_4812wt_689
What set up are you doing? Just plugs are bulkhead connectors as well.
A few on eBay USA.
Others to look for Daniels,Harting,glenair.I had a quick look for the ones I used to use but some of the Daniels with the interchangeable tooling are more expensive.Pretty sure as all the crimp tools came from RS or maybe some from Farnell.I dont have one otherwise you could have borrowed it.I only have a few takbro tools now.Besides all the lin bins about 600 with good tools in there was also four or so tea chests with broken hand tools in.Most only had a broken spring
.If anything comes back to me I will post at a later date.Oh and the electronics company I worked at moved premises so all the broken stuff was binned (bit of salt to rub in there)
