crimping tool
Trying to find a cheap deutsch crimping tool ,any contacts would be good. Many thanks
Guess you've tried R S Components?
Pretty tricky to get one. I have a CAT issue jobby or two ($700)
I noticed a few on EBay.COM. Shipping would be tricky IDE pop one in the post if I wasn't state side. |
A few on eBay USA.
The only one worth owning. http://www.ebay.com/itm/Harley-OEM-D...#ht_4812wt_689 What set up are you doing? Just plugs are bulkhead connectors as well. |
Originally Posted by .Ross.
(Post 5904255)
A few on eBay USA.
No problem.
You looking for a kit? Can get you the part # for the pins and plugs. |
(Post 5904556)
No problem.
Up....
Others to look for Daniels,Harting,glenair.I had a quick look for the ones I used to use but some of the Daniels with the interchangeable tooling are more expensive.Pretty sure as all the crimp tools came from RS or maybe some from Farnell.I dont have one otherwise you could have borrowed it.I only have a few takbro tools now.Besides all the lin bins about 600 with good tools in there was also four or so tea chests with broken hand tools in.Most only had a broken spring :roll:.If anything comes back to me I will post at a later date.Oh and the electronics company I worked at moved premises so all the broken stuff was binned (bit of salt to rub in there) :cry:
© 2024 MH Sub I, LLC dba Internet Brands
