Sierra Cosworth 4x4 fuel line
Old May 4, 2012 | 11:01 PM
Simplon's Avatar
Simplon
Default Sierra Cosworth 4x4 fuel line
Good evening everybody,
Mi sierra is losing fuel, and it is in the connectors wich connect the tecalan lines (hard plastic) with metalic line which is fixed to the body.
Do you know how can I take this connectors out of the metalic line, in its both sides?
Does exist any way to do it easily? They are extremely hard, and I begin to think that there is a proper way to take them out
Thanks in advance.
Old May 7, 2012 | 08:54 PM
tosh's Avatar
tosh
I was told you have to push something into the two holes which releases the mechanism and then pull it apart, even though I tried this and it didn't work
Old May 12, 2012 | 11:11 PM
Simplon's Avatar
Simplon
Tosh, it is how you said, and it works.
You don't need to push both holes. You only have to push one of them and you can release it.
Thanks!
Old May 13, 2012 | 05:25 PM
tosh's Avatar
tosh
Glad you had better luck than me.
3doorcozmess
Aug 21, 2015 11:17 AM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
RSMK4TURBO
Aug 13, 2015 08:06 AM
muffster
Aug 12, 2015 08:14 PM
