Oil Pressure gauge - mismatched sender?
Old May 4, 2012 | 08:09 PM
Iain Mac's Avatar
Iain Mac
Default Oil Pressure gauge - mismatched sender?
I fitted a set of VDO gauges to my car and finally wired them up today. Volts and oil temp seem to be OK, but oil pressure goes off the scale (5 bar) when I start the engine, and stays there. The sender has a separate terminal for a warning light, but that isn't coming on with the ignition.
Does that sound like a 10 bar sender has been supplied, is the sender faulty (big reading and no warning light coming on), or could the gauge itself be faulty? And is there a way to test both?
Old May 4, 2012 | 08:50 PM
martysmartie's Avatar
martysmartie
The sender and gauge have to be calibrated, ground the warning light and see if it illuminates, which it should, if so then the sender is your problem.
Martin
Old May 4, 2012 | 10:50 PM
john_p_b's Avatar
john_p_b
double check the wiring, got vdo gauges in my kit car and if the ground comes off the gauge goes off the scale.
Old May 6, 2012 | 12:08 PM
Iain Mac's Avatar
Iain Mac
Thanks guys, it seems that my sender is bollocksed.
Cleaned both terminals and that fixed the light, but made no difference to the gauge.
I earthed the cable and the gauge went to 0, so I put the polarity tester on and found that the sender terminal for the gauge doesn't earth, even if I stick the probe right in the centre.
Now to find a replacement.
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
Brickhouse
Sep 21, 2015 11:00 AM
coscor86
Sep 20, 2015 01:21 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
