Brand new big power yb build!!may split!!!!
Old May 2, 2012 | 09:37 PM
glockenspiel lover's Avatar
glockenspiel lover
Default Brand new big power yb build!!may split!!!!
This engine was built for a 2wd race car iv been building but has never been finished hence selling this engine..
Built from a good second hand 4x4 200 blocked engine by joe stevens and just waiting to be bench dynoed and mapped by ahmed bayjo..
0.5 oversize coworth race pistons with valve cut outs and 7.8.1 cr
shotpeened rods arp rod bolts
lightwieght std std sized journal crank
cosworth big and main end bearings
block long studded and spray jetted
titan dry sump kit complete with brand new 3 stg scavenge pump
wrc mountune hg
head built from a very good 138.9 depth head and completly re worked by niel roper with oversized inlet valves nimonic exhaust valves and scmitl valve springs
it was line ported before being hand ported to over 27mm inlet ports and 26mm exhaust ports..
it runs custom cams and solid lifters with piper verniers
the head cams lifters etc etc cost £4k alone!! THE HEAD AND CAMS ETC NOW SOLD!!!
500 spec hart plenum cover and rs 500 throttle body £750 complete with fuel rail
the turbo is a to4z hybrid built by vince at cr turbos and runs a .82 twin scroll ex housing and is an awesome turbo £1000 cost £1400 unrun
the turbo sits on a swedish style twin scroll tubular manifold and a pro gate waste gate 50 mm i believe.. £800 for manifold and w/g
the turbo wastegate and manifold are prov sold
this is running on a motorsport mountune spec t6 ecu and pectel loom £1000 with loom can run 4 or 8 injector
this engine hasnt even been run yet but will be mapped in the next couple of weeks by either ahmed bayjo or if joe can get him mark shead
the engine is going to be circa 650 hp and 580lb ft on pump fuel..
it has cost me a fourtune and has taken forever to get done and now sadly has to be sold
the engine looks awesome and mint and can and will be vouched for by joe and whoever maps it..
Full engine mapped and complete ready to drop into a car...£10.5 k ovno
Iv had some interest on the complete head so that not for sale as yet and as for the bottom end with dry sump kit im happy to keep this for another project unless I get a good offer for it ??
please call jd if your intrested on 07712536242
Old May 4, 2012 | 06:18 PM
Dimma4x4's Avatar
Dimma4x4
Hi mate just wondering what the full cost ov the engine to build an everything you supplied with it??? Thanx Lawrence
Old May 4, 2012 | 06:37 PM
glockenspiel lover
That whole engine complete with loom and t6 ecu etc from scratch has cost around £17 k..
I had quotes for nearly double that from 2 other well known tuners though!!lol
Old May 4, 2012 | 07:03 PM
glockenspiel lover
Head and cams etc now sold so all other bits for sale
thanks
Old May 4, 2012 | 11:00 PM
Dimma4x4's Avatar
Dimma4x4
Thanx 4 the reply sounds like a cheap engine when u put it like that good luck wiv the sale
Old May 5, 2012 | 11:15 PM
jamie956's Avatar
jamie956
What would you want for the bottom end with out the dry sump, whats required to return to std sump/oil pump.
Old May 6, 2012 | 12:57 PM
glockenspiel lover
I can supply bottom end complete with std sump and pump etc..
All the long stud kit and nuts so will just need a h/g and top end..
£3500??
cheers
Old May 6, 2012 | 12:59 PM
Hoogi's Avatar
Hoogi
How much for the dry sump kit ?
Old May 6, 2012 | 01:02 PM
glockenspiel lover
Its the alloy titan 3 stg scavenge system in perfect condition with a brand new pump
£750??
cheers
Old May 7, 2012 | 07:42 PM
yblee's Avatar
yblee
Default how much
i know you have your prices listed,but how much would you do and turbo and manifold with w/g if i had both of them,got some bits i can place to get funds towards yours cheers lee
Old May 7, 2012 | 08:24 PM
glockenspiel lover
you have pm..
Old May 7, 2012 | 09:12 PM
AJC's Avatar
AJC
Pics of manifold please? And who made it? Cheers
Old May 8, 2012 | 12:27 PM
glockenspiel lover
It was originally a julian godfrey rally x manifold for a gt 40 with t4 flange that has been converted to a t3 flange and is beautifully done..
I will be up at joes place tomo and will have some proper pics put up of it but there is another member on here with first refusal
cheers
Oct 9, 2015 07:38 PM
borboyous
Aug 22, 2015 11:17 AM
Aug 20, 2015 09:21 PM
Blown Hell
Aug 5, 2015 07:22 AM
