Condensation problem
Old May 2, 2012 | 07:31 AM
0sykes0's Avatar
0sykes0
Default Condensation problem
What is the best way of get rid of condensation in my headlight? I know you've probably heard this question a thousand times. Cheers
Old May 2, 2012 | 07:59 AM
focusv8's Avatar
focusv8
Take the headlamp and bulbs out, put it on a central heating radiator with the hole facing up.
Then before you put it back in run sealer around the join between the glass and rear section, it's got condensation in because it leaks.
Old May 2, 2012 | 06:03 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Bring it over one evening this week Luke and I'll sort it with a permanent fix to stop it re-condensating
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
