T5 Gearbox & Ford Diff oils
Old May 1, 2012 | 08:24 PM
BRAMMER's Avatar
BRAMMER
Default T5 Gearbox & Ford Diff oils
I have done the search and found too much information to digest
Basically what is recommended for a 3dr:
standard T5 gearbox ???
and
Standard Ford 7.5" rear diff ??
Many thanks
Old May 1, 2012 | 08:39 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My box has ATF in it, still going fine.
Gripper diff in mine so a different oil to a standard diff
Steve
Old May 1, 2012 | 08:54 PM
1374lee's Avatar
1374lee
Opie Oils will give you good advise with this Chris,I purchased for my 3dr and for the escos,top guys for advise on this.
CheeRS.Lee.
Old May 1, 2012 | 08:56 PM
DAN400's Avatar
DAN400
i used to run mobil 75/90 in my box, then it started sticking in 4th,
it had broken and bent some sort of guide things, cant remember now what they were called,
the man that sorted it said it was most likely down to the oil i was running and to run the genuine ford mtx 75/90 oil ,
i did as he said , so far so good
Old May 5, 2012 | 07:31 PM
BRAMMER's Avatar
BRAMMER
CheeRS.Lee.
Checked his site again and it suggests either
Millers Oils Millermatic UN ATF
or
Fuchs TITAN ATF 3000 Multipurpose Dexron II ATF
Are both these products as good as one another?
And for the diff he suggests
Fuchs TITAN Gear Hyp 90 Hypoid Gear Oil GL5 80w-90
Any feedback on any of the said products appreciated
Old May 5, 2012 | 07:34 PM
1374lee's Avatar
1374lee
Think I had Redline ATF for the g/box,can't remember for the diff but 80w90 possibly.
Thanks.Lee.
3doorcozmess
Aug 31, 2015 05:15 PM
mattman1234
15
Aug 14, 2015 10:05 PM
Gadget
Aug 13, 2015 08:19 PM
COLEYST200
Aug 3, 2015 08:55 AM
