Head and engine gasket advice
Old May 1, 2012 | 05:42 PM
nuttynil's Avatar
nuttynil
RS nutta
Default Head and engine gasket advice
Been looking at parts on the eBay and web .First on my list is gaskets for the rebuild the head gasket that is on there is a grp a one but the block has been wire ringed .Can anyone recommend a head gasket type to use and need good quality gasket kit .cheers Neil
Old May 1, 2012 | 06:44 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Im using a small turbo escos from matt lewis with original ford head bolts on my 3 door. The gasket is a victor reinz make.
Old May 1, 2012 | 07:06 PM
bigad4x4's Avatar
bigad4x4
Hiya bud Matt Lewis on here can supply the parts my block is wire
ringed and dowled by Andy Fisher which uses a group A gasket and
standard bolts when refitting the gasket has to be filed perfectly so the
gasket marrys up with the wire rings so they bite together got to be
perfect! Andy also drilled 6mm holes on the inlet side too
RUBY123
Oct 22, 2023 12:04 PM
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
knight19770
Aug 4, 2015 12:36 PM
