whats it worth - yb fresh built engine- PROV SOLD
formerly beefy-rst-2
NOW PROVISIONALLY SOLD PENDING DEPOSIT THIS EVENING
THAKS FOR EVERYONES INPUT GUYS
BEEF
its all going , looking to work out a price for me engine ,
spec is
bottom end
stock comp
cosworth " 200 " block with 2222 stamps in dizzy face , honed and decked
6 long stud conversion
crank on .25 mains and bigs ( for peace of mind ) brand new shells
brand new oil pump
2wd big wing sump with aeroquip fitting
standard rods - arp conrod bolts - brand new little end bearings matched to gudgeons
.5 mm stock mahale pistions with valve cutouts by scs
brand new mahale piston rings
aeroquip fittings for block breathers
brand new waterpump
brand new cometic gaskets used throughout and new bolts
skimmed 2wd (iirc ) flywheel
2wd engine arms , alt mount and ps mount
fully painted and detailed , looks like brand new
head
late spec 4x4 head , well within skim - stripped , chemically cleaned and then rebuilt after porting ect all faces blocked flat for perfect seal
spec ,
stock valves cleaned & polished
brand new burton power bronze rifle guides
new valve seals
ported & polished head and port matched inlet trumpets
2wd thermostat housing ( not in pic )
cometic gaskets
brand new ina lifters ( still sealed in packaging )
pair of stock camshafts
all painted ready to fit ,
all parts unless stated supplied by matt lewis ,
looking for prices for top and bottom please guys ???
full detailed build diary for the engine in my resto
pics
the coil on plug rocker has price set , thanks
BEEF
spec is
bottom end
stock comp
brand new oil pump
brand new waterpump
head
spec ,
new valve seals
cometic gaskets
pics
I got Ł5k for mine, which was very similar spec, all built by Mark Shead, with a Hart inlet too
Probably worth more, but unfortunately not many people seem to have money to spend on a nice engine at the moment
DixieTheKid
11
Jun 6, 2020 11:20 AM
