Sierra steering bush...
Old May 1, 2012 | 12:44 PM
Gav Diamond's Avatar
Gav Diamond
Default Sierra steering bush...
Hi guys im after some info if anyone can help.
I need to replace the steering bush on my 3dr as mine had split and the replacement I bought were found to be very dangerous
Old
Replacement
I have been told numerous times that one from a Land Rover fits and is pretty much the same as the standard Ford one.
Does anyone know what Land Rover model, year or part numbers please?
Thanks
Gavin
Old May 1, 2012 | 01:01 PM
gibbo frst's Avatar
gibbo frst
i got mine from island 4x4 in kent.. was 25 quid i think.. says on receipt 89-94 land rover discovery
comes as pictured .. although im using the poly one at the moment and having no probs..
Old May 1, 2012 | 03:05 PM
opposite lock's Avatar
opposite lock
I have one of them also have you modded your sierra one yet? If so how did you do it. I can confirm that they are the same bush .
Old May 1, 2012 | 03:15 PM
Rob Virgo's Avatar
Rob Virgo
Nice to know lads
Old May 1, 2012 | 03:39 PM
gibbo frst's Avatar
gibbo frst
ive not fitted the land rover one to mine im just keeping encase anything goes wrong with the poly bush.. it has been fine so far though..
Old May 1, 2012 | 04:02 PM
Gav Diamond
Think I found it
http://www.island-4x4.co.uk/steering...78-p-1193.html
Thanks for the info, much appreciated
Just to confirm, the trouble was with the cheap ebay ones and believe the ones from Burton Power were much better
Old May 1, 2012 | 05:41 PM
Toe Knee's Avatar
Toe Knee
As said the ones from burton are proper made poly ones and don't think people have had probs with them, I know jamesH had a landrover one not sure if he fitted it or not before selling up his cossie.
I was lucky I've got a good one on the car and a near new coupling spare for mine!!
Old May 1, 2012 | 08:19 PM
BRAMMER's Avatar
BRAMMER
Cheaper through the link above - £35 delivered but they are on ebay too
http://www.ebay.co.uk/itm/RANGE-ROVER-CLASSIC-LOWER-STEERING-SHAFT-NTC8478-/260477118977?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item3ca5a56a01
Old May 1, 2012 | 09:07 PM
Puss2's Avatar
Puss2
Formerly know as Puss
Are the Land rover ones above the same as a 2wd saph as i need to change mine?
Old May 2, 2012 | 09:12 PM
kieran_macca's Avatar
kieran_macca
where do you get the polybush one? couldnt find it on burton power, mines is barely hanging on!
Old May 2, 2012 | 09:27 PM
Gav Diamond
Here you go mate
http://www.burtonpower.com/poly44.html
Old May 3, 2012 | 09:58 PM
daz1968's Avatar
daz1968
I can also confirm landrover one is spot on, I used one on mine, only thing I did was after bolting it to my coupling I put a spot of weld on the nuts so no chance of coming undone, although easy to grind off if it ever needs doing again. I would trust one of these rather than a poly one, think I have seen solid alloy ones for sale but presume the rubber would be better.
Old May 5, 2012 | 03:59 PM
tosh's Avatar
tosh
I have just ordered one, saved me a lot of foot work
Thanks to the OP for posting the question and Gav Diamond for the link above, I just noticed mine was split yesterday and luckily noticed this post.
Old May 5, 2012 | 09:12 PM
Puss2's Avatar
Puss2
Anyone?
Old May 5, 2012 | 09:45 PM
gibbo frst's Avatar
gibbo frst
yes mate same as 2wd..
Old May 6, 2012 | 09:01 PM
Puss2's Avatar
Puss2
Sweet will order one for mine cheers
Old May 10, 2012 | 10:41 PM
Puss2's Avatar
Puss2
Right got mine today is it easy to get the bush off the new one? And has anyone modded the land rover one so you can use it all seems a waste to throw it away
Old May 11, 2012 | 03:00 AM
Gav Diamond
Would like to know the same bud, have got the new one but not had time to mess about with yet..
Old May 11, 2012 | 03:12 PM
tosh's Avatar
tosh
I got mine yesterday but as above have not had time to even look at it yet, it would be nice if daz1968 could take a pic to show what he did
Old May 11, 2012 | 04:49 PM
daz1968's Avatar
daz1968
Sorry but it's on the car and very difficult to take a pic of at moment, I basically ground the rivets to remove the rubber section from both couplings, then fitted the landrover rubber section to the cossie one and bolted it with 4 high tensile bolts, then I just put a blob of weld on each nut to be 100% sure they can't come undone, been like it for a few years now and had no issues on mot or in operation. Its easy to do as the landrover coupling I had was totally different to the cossie one but the rubber was identical.
Old May 11, 2012 | 05:03 PM
tosh's Avatar
tosh
No worries, I thought you had used the complete part and put a spot of weld on the two pinch bolts I didn't realise you had removed the bush completely, I might try and use the complete shaft as it looks to have better joints.
Old May 20, 2012 | 10:44 PM
Gav Diamond
Update
Finally got round to fitting the bush today.
Basically I just drilled the heads off the rivets and used a punch and hammer to knock them through seems a waste to throw all the joints away but there is no way any of it will fit so in the bin it goes, lol.
The holes on the bush do not line up 100% but I put the bush in the vise and squashed it only a small amount and then the holes lined up so nut and bolted it and then turned 90 degrees and squashed again to do the other piece.
The finished piece...
Good as new and feels very tight
Old May 21, 2012 | 03:04 AM
English's Avatar
English
One thing that's good to do is use some TipEx or something to mark where the flexible coupling splines line up with splines on the steering rack. Saves you a lot of buggering around trying to get the steering coulum straight again at the end. Maybe take a pic of how it was before you started too!
Start with the steering wheel dead straight, and lock it in place if need be...not essential...
If you hate yourself (cos it's an annoying job), it's a Good idea to do the steering column bush at the same time if you can be fooked. Makes the car feel nice and tight again. You can buy new bushes for a few quid on EBay.
Was a horrible job to do...but bearing in mind you have the column apart anyway, is worth doing. Definitely get the workshop manual (PDF CDs available online) for this one as safety is obviously paramount ESPECIALLY where your steering is concerned!!!
Old May 21, 2012 | 09:36 AM
opposite lock
Thats cool i shall be getting my LR bush on the saph coupling i may add some piccies.
Old May 21, 2012 | 08:56 PM
Puss2's Avatar
Puss2
Nice info there Gave cheers
Old Aug 6, 2012 | 07:27 PM
Ridgey's Avatar
Ridgey
Ordered Land Rover one, my poly one is looking a little worse for wear after about 3 yrs (it wasn't one of the cheap ebay jobs either).
Old Aug 6, 2012 | 07:54 PM
DaveCrack's Avatar
DaveCrack
Thanks for bringing this btt! Totally forgot about this thread...
Old Jan 7, 2019 | 10:35 PM
BryanKing's Avatar
BryanKing
Default Sierra steering shaft
Searching for a shaft and joints like this one pictured for a Sierra. I am in the USA and searching for someone who will sell and ship to me.
Old Jan 8, 2019 | 05:53 PM
Mark V8's Avatar
Mark V8
I've got one down the shed somewhere mate, no idea what it would cost to post though...
Old Jan 8, 2019 | 06:58 PM
BryanKing's Avatar
BryanKing
I appreciate that. I need a new one or a correct part number for a new part.
Thanks
Old Jan 8, 2019 | 07:58 PM
Mark V8's Avatar
Mark V8
Thanks
You will be very lucky to find a new 2 wheel drive Cosworth joint.
Try and get hold of a dodgy copy of Microcat for part numbers.
Old Jan 9, 2019 | 08:13 PM
BryanKing's Avatar
BryanKing
Do you feel confident that is a Cosworth joint and shaft. ? I thought it was from a Ford Sierra
Old Jan 9, 2019 | 08:19 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I fitted a polly one in mine when I refurbished it. Can’t see any reason why someone would say it’s dangerous unless it wasn’t put together right. Has spacers the bolts go through to stop you over tightening it and damaging the polly. And 2 of the bolts are a special shape to stop the two half’s moving.
Old Jan 9, 2019 | 08:22 PM
Mark V8's Avatar
Mark V8
Not sure how unique the Cosworth one is to be honest, there's one on ebay at the moment
https://www.ebay.co.uk/itm/Sierra-Co...UAAOSw8KJb0FGs
Old Jan 9, 2019 | 08:25 PM
Mark V8's Avatar
Mark V8
Pics of the one I had down the shed, this is from a Sierra Sapphire Cosworth 2WD
Edit to add Microcat screenshot
chowfornow
14
Jan 5, 2019 09:01 PM
muzzman1
Sep 30, 2015 08:59 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Adam Graham
Sep 6, 2015 06:04 AM
