what tyres ?
Old Apr 30, 2012 | 06:29 PM
Northants Ford Fan's Avatar
Northants Ford Fan
Default what tyres ?
Hi guys, yes another what tyres post
basically looking to find a slight harder wearing tyre than the toyo t1rs as they have only lasted about 15k, cant really fault the way they grip but they do wear farely fast.
so what tyres do you guys rate ? they need to be available in 205 45 16 and ideally have a rim protector as the girlfriend drives the car
Old Apr 30, 2012 | 06:37 PM
scoooby slayer's Avatar
scoooby slayer
so what tyres do you guys rate ? they need to be available in 205 45 26 and ideally have a rim protector as the girlfriend drives the car
205 45 26 is it a tractor lol
Old Apr 30, 2012 | 06:46 PM
Northants Ford Fan
doh will edit it now
Old Apr 30, 2012 | 06:57 PM
Dal_'s Avatar
Dal_
Me and the O/H have had Uniroyal Rainsport 2 and have found they wear better than T1Rs and have much better wet performance and about the same dry.
And they have a bit of a rim protector.
Old Apr 30, 2012 | 08:15 PM
Northants Ford Fan
what do you guys think of Hankook Ventus V12 EVO K110 tyres ? as ive seen a few reasonable reviews on them
Old Apr 30, 2012 | 09:36 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
15k miles is good for atire i'd say. Or did you mean 1.5k miles
Old Apr 30, 2012 | 09:45 PM
phil_rs's Avatar
phil_rs
yam yammer
http://www.tyrereviews.co.uk/Article...-Tyre-Test.htm
Old May 7, 2012 | 01:10 PM
valbertini's Avatar
valbertini
15k lifetime is not bad, but could be better. But you know, tyre wear depends on several parameters, not only on tyre compound. Same tyres perform different for each driver.
This tyre recommendations are also so personal. Expectations and experiences always differ from each other. There is no single solution for it.
I would also recommend you to check the links phil_rs posted. There are alternatives better than Toyo out there.
For me, I can only rate and recommend you the tyres I'm currently using.
My tyres are Lassa Impetus Sport and am happy with them.
Mark RS
Mar 5, 2021 06:08 PM
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
