Some Tasty Engine Parts & Other Bits
Old Apr 29, 2012 | 04:32 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default Some Tasty Engine Parts & Other Bits
Set of Farndon rods (Burton power)
Immensly strong, standard geometry, over £700 brand new, never been used at all so as new. Also come with a set of brand new ARP rod bolts: £500
Brand new 2wd high pressure oil pump, never used.
£100
Standard/Standard crankshaft, perfect condition ready to go into an engine.
£450
Brand new set of 16 genuine YB Cosworth valves, still in ford boxes, 8 inlet & 8 exhaust. Cost £490 brand new, still unused, never fitted : £380
Brand new YB JE 4x4 forged lightweight rallycross pistons, standard bore 8.5:1 CR with valve cut-outs, good for silly power, can be machined to lower the CR if needed. Over £750 brand new, never used: £550
Other bits:
Set of 4x4 rear 100mm drive shafts, complete with stub shafts: £50
Mongoose 3" outwardly rolled back box, good condition: £50
Jaguar 10.5" non powerlock diff, hugely strong (1000Bhp+!) £40
Old May 7, 2012 | 07:19 PM
RWD_cossie_wil
Up! Some very nice bits here!
Old May 7, 2012 | 07:25 PM
CHUNKYS RS's Avatar
CHUNKYS RS
any pics of the back box
Old May 7, 2012 | 09:47 PM
skinnarbi's Avatar
skinnarbi
Tyres - It's What I Do
Is the diff a straight swap for the one in a 2wd saff?
Old May 7, 2012 | 10:18 PM
RWD_cossie_wil
Nope! Lots of beam mods.
Old May 8, 2012 | 11:25 PM
langer's Avatar
langer
What's the back box 2 or 4wd or does it not matter is the exhaust pipe itself 3" or just the tail pipe? Any pictures? My 2wd has decided to rattle today cheers
Old May 31, 2012 | 06:28 PM
RWD_cossie_wil
Up!
Old May 31, 2012 | 10:07 PM
Mr C's Avatar
Mr C
What's the difference between 4x4 and 2wd rear shafts I thought they were the same? I'll take them if they fit a 2wd and the joints are in very good condition.
Old May 31, 2012 | 10:11 PM
RWD_cossie_wil
2wd have 108mm flanges, 4x4 100mm. 2wd won't accept the 100mm joints, the stub shafts are the same.
Old Jun 4, 2012 | 10:27 PM
RWD_cossie_wil
Backbox pic as requested
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
Zoggon
Aug 10, 2015 10:39 AM
