Finding out what category write off a car is???
Old Apr 29, 2012 | 01:20 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Default Finding out what category write off a car is???
Hello all quick question a friends mum drove over a curb in her 206cc bending the subframe ectect was going to pay me to fix it but then decided to go through the insurence and they wrote it off
Ive now bought the car back off the insurence but how do i fined out what catorgy thay have placed it in :/
Old Apr 29, 2012 | 01:51 PM
Pudnpepsi's Avatar
Pudnpepsi
Fix or repair daily....
Old Apr 29, 2012 | 02:06 PM
DAN P's Avatar
DAN P
Send me the reg tomorrow can see if its on are system
Old Apr 29, 2012 | 02:57 PM
slammedorion's Avatar
slammedorion
Or apply for the docs, if they come back it'll be cat d. If they don't you'll get a letter saying it requires a vic check before you can have the docs.
That will be a cat c.
Old Apr 29, 2012 | 03:13 PM
Paynee's Avatar
Paynee
If you do a search online, there is a number that you can call to see if a car needs a VIC carrying out, i think the number may actually be on the form you send off to book a VIC, if it needs a check its cat C, if not then cat D. if you use a txt check it will cost you likewise if you apply for a logbook which i presume you have access to if you got the car off a friend
Old Apr 29, 2012 | 09:10 PM
vaughant's Avatar
vaughant
Wrong,cat c does not always require a VIC check.
Type the reg into the Dvla vehicle enquiry website and it will show you if there's a VIC marker set against it,if so then it's cat c.
Best way to check is hpi etc but a touch pointless if it's already had a VIC marker set against it.
Old Apr 29, 2012 | 09:16 PM
vaughant's Avatar
vaughant
Try here: https://www.taxdisc.direct.gov.uk/Ev...execution=e1s4
That's my mothers corolla which needs to be VIC checked,has needed to for the last 5 years!!!
Old Apr 29, 2012 | 09:19 PM
clarke5700's Avatar
clarke5700
yea gota go sort the log book with him some time so when itssent off i sould fined out when i get it back?
Old Apr 29, 2012 | 09:24 PM
vaughant's Avatar
vaughant
You can find out now in the link above!!!
Or google vehicle enquiry.
Like I said above,if you get the logbook back that's no guarantee it's not cat c,it just doesn't require a VIC check but to all intents and purposes your logbook stays clean and that's a good thing.
MK Motorsport Matt
75
Nov 15, 2015 11:22 PM
Sultzi
12
Aug 16, 2015 01:08 PM
Botts
Aug 13, 2015 04:16 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
onionlover
Aug 6, 2015 03:20 PM
