Coil pack plug leads
P8 Managed S1 with ALS
If you run a coil pack on a cosworth managed car what leads do you use
I bought a set of magnecors a while ago before i was going to run cosworth managment so im guessing now i need to buy some more and sell these
Thanks
Ross
Thanks
Ross
well its a cvh coil pack bracket and coil that you use for cossie management with wasted spark, I used to run it.
I've also heard you can drill the coil pack and use erst leads if you have a decent set.
Not sure about drilling a coil pack though i dont fancy doing that ! lol
deathrider666
Sep 28, 2015 06:12 PM
