Custom BMW e30 / cosworth conversion parts
Old Apr 29, 2012 | 09:41 AM
m3cosworth's Avatar
m3cosworth
Default Custom BMW e30 / cosworth conversion parts
For sale are custom conversion parts to allow a BMW e30 to run with cosworth yb turbo engine.
I've had these parts for ten years running a e30 318 lux with a cosworth engine then after an e30 m3.
The custom cross member was fabricated to clear the cosworth sump which sits lower than the BMW sumps. It also fits on the original BMW fixing points and will bolt straight onto any e30 chassis legs. It positions the engine to clear the BMW master cylinder. Can be fitted into lhd and rhd cars. You use the cosworth engine mounts which are not included in the sale.
The engine was moved into an e30 m3 shell two years ago and I recomissioned the part as the paint was peeling and suffering very minor surface rust. it was acid dipped. Rust treated, primered and painted. It is in good condition although oily in the pics.
The prop shaft is an e30 prop mated to a ford cosworth item from a sierra. It allow you to use a cosworth t5 gearbox and mate it straight to an e30 diff/LSD. This again was reconditioned 1 year ago where it was professionally stripped balanced and powder coated. I may have the receipt for this which cost me 100 pound i think. It is in excellent condition.
These parts take the biggest headache out of the conversion and the engine will drop in. All you need to do is plumb and wire it in!
Pick up or courier only due to size.
£250
Old Sep 24, 2012 | 11:26 AM
flood118's Avatar
flood118
hi mate have you still got eny of the bits left that u had for sale from e30 cosworth converion thanks
Old Sep 25, 2012 | 11:15 AM
m3cosworth's Avatar
m3cosworth
I've only got the prop and cross member left
Old Sep 25, 2012 | 04:26 PM
flood118's Avatar
flood118
hi there mate il bye both prop and cross member my mobile number is 07733475443 thanks pete
Old Sep 25, 2012 | 07:24 PM
PF Ben's Avatar
PF Ben
Sold to me already!
big_Rad
Sep 15, 2017 09:36 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
