Mondeo Fault Code Reader
Old Apr 28, 2012 | 03:57 PM
Brian's Avatar
Brian
Default Mondeo Fault Code Reader
Can anyone recommend me a fault code reader? I have 2 Mondeo's a 56 plate ST tdci estate and a 53 plate 2.0 lx but my dad also has a 1.8 zetec 2001
I would like if possible one that what cover them all
Brian
Old Apr 28, 2012 | 04:04 PM
GVK.'s Avatar
GVK.
Problem with most code readers, is they will only do the engine. If that's all you need to check then something like this will be fine.
http://www.gendan.co.uk/product_GCR25.html
Not used it myself, but have seen mentioned Formidable which is a PC based software.
http://magik-tool.com/formidable.html
Apparently this will do injector coding and access all ECUs
Old Apr 28, 2012 | 10:06 PM
Brian's Avatar
Brian
Cheer's mate
Are the ones on ebay any good?
Brian
Old Apr 28, 2012 | 10:08 PM
GVK.'s Avatar
GVK.
Which ones are you looking at? If they support the vehicles you have,then should be ok.
Old Apr 28, 2012 | 10:22 PM
Brian's Avatar
Brian
Was looking at this one http://www.ebay.co.uk/itm/1607865085...84.m1423.l2649
Have some for Ł20 and some for Ł100 but unsure what to go for
Brian
Old Apr 28, 2012 | 10:31 PM
GVK.'s Avatar
GVK.
Looks fine for the money imo!
Old Apr 30, 2012 | 02:27 PM
Brian's Avatar
Brian
Apparently that one will work on 2 of them but not the 2.0 tdci as is to old 53 plate
I have just found this for the 53 plate tdci, any good? Says it can re code injectors aswell ?
Brian
Old Apr 30, 2012 | 02:50 PM
M K's Avatar
M K
I bought an F-Super off ebay for Ł24 i think it was and that reads and re-coded my new injectors on my 53 plate zetec-s tdci
Old Apr 30, 2012 | 03:23 PM
Brian's Avatar
Brian
This one mate http://www.ebay.co.uk/itm/Ford-Super...#ht_1907wt_929
Brian
Old Apr 30, 2012 | 03:36 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
F-Super can recode injectors, but it can't clear excessive knock fault codes. A lot the guys on the Mondeo forums swear by them.
Old Apr 30, 2012 | 03:43 PM
Brian's Avatar
Brian
So worth buying one then you think Dan? Does it work on newer mondeos as i also have a 06 plate tdci st
Brian
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
