Best clutch for 2.0 zvh turbo
AP Racing CP2000-35, good for 300ftlb and is not a paddle so drives much nicer in town etc. £400.
Pedal conversion is literally just a mk5/6 pedal and quadrant, gives more travel on the cable as the high pressure covers require it to fully disengage the clutch.
If your ZVH then I also recommend fitting an IB5 gearbox as the fiesta BC box will last about 10mins with any sort of decent power/torque, IB5's are not much better but they are at least better!
lol
lol
Yeah if you've not got an LSD then get one! A Racing Puma one (what I run) drops straight in as does a S2 RST one with a little grinding off the edge to fit the crown wheel.
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
