Water pressure
Old Apr 27, 2012 | 06:31 PM
RS-Rikki's Avatar
RS-Rikki
Default Water pressure
One of my water pipes burst so I have replaced the burst one I have gone to start it and another pipe has burst but it's hissing very loudly as if there's alot of water pressure all other signs of head gasket are not there so I'm maybe thinking stuck thermostat or bad air lock can I run it without thermostat for a while as im looking for a new engine or any other ideas cheers
Old Apr 27, 2012 | 07:10 PM
studabear's Avatar
studabear
Much bubbling coming back through the header tank while running with the cap off?
Stuck thermostat would cause over heating before bursting hoses imo
Old Apr 27, 2012 | 07:35 PM
RS-Rikki's Avatar
RS-Rikki
I tried taking cap off while engine was hot water pissing everywhere
Old Apr 27, 2012 | 09:17 PM
studabear's Avatar
studabear
try it from cold, or see if you can get a garage to do a sniff test
Old Apr 28, 2012 | 06:35 AM
RS-Rikki's Avatar
RS-Rikki
There is water coming back header and seems like running around everywhere so I'm maybe thinking whip thermostat out and run with out one? Just let car warm up properly
Old Apr 28, 2012 | 07:57 AM
RS-Rikki's Avatar
RS-Rikki
Also where the plug connects to the thermostat there I two black wires going straight into the plug but there is a random brown wire with a female electrical connection just hanging there and I'm guessing that's y my temp gauge don't work I looked for a hour where it goes I can't see anywhere
Old Apr 28, 2012 | 10:14 AM
beaver rs 88's Avatar
beaver rs 88
in the garage
There should be a sensor on the front of the cylinder head for the coolant temp
Old Apr 28, 2012 | 05:34 PM
RS-Rikki's Avatar
RS-Rikki
Yeah with two black wires like a lamb sensor on side of thermo housing but there's a random brown wire
Old Apr 28, 2012 | 06:02 PM
beaver rs 88
in the garage
On mine that wire goes to a sensor on the front of the cylinder. Upload a picture of it and I'll see if its the same as mine fella.
Old Apr 28, 2012 | 10:11 PM
BRAM's Avatar
BRAM
There should be a sensor on the front of your head, inbetween the exhaust manifold and the thermostat for your temp gauge, and the one on the side of the thermo with the 2 wires is for your fan switch, does your fans work?
Old Apr 29, 2012 | 08:11 AM
Ryoishikawa's Avatar
Ryoishikawa
Mine turned out to be the radiator when his happened
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
