Volvo 850 coil in Sierra
Old Apr 26, 2012 | 07:25 PM
Duncan009's Avatar
Duncan009
Default Volvo 850 coil in Sierra
Hi
Do you think i can temporary replace the igniton coil in Ford Sierra 1991 DOHC with one from a Volvo 850. Need troubleshooting
Old Apr 26, 2012 | 07:33 PM
Bailes1992's Avatar
Bailes1992
850 only came with 5 cylinders. The middle number of the old Volvo'swould indicate the amount of cylinders. I.e. 740 and 760 were the same cars but with different engines.
Old Apr 27, 2012 | 11:34 PM
langer's Avatar
langer
Should that matter it's only a coil!
QUOTE=Bailes1992;5894169]850 only came with 5 cylinders. The middle number of the old Volvo'swould indicate the amount of cylinders. I.e. 740 and 760 were the same cars but with different engines.[/QUOTE]
Old Apr 28, 2012 | 08:13 AM
daz1968's Avatar
daz1968
You should be able to test with any coil of correct voltage to prove if there is any issues with the old one, but some will give a higher voltage than others
Old Apr 28, 2012 | 10:16 AM
martysmartie's Avatar
martysmartie
It should work, the output can vary, so long as it is only a temporary measure you should be ok I should think?
The only difference with coils is some cars have 'ballest ignition systems', this is where the loom has a resistor built in which reduces the power to 9V which the coil uses opposed to 12V, so you have 'ballest' and 'non ballest' coil's respectively.
Martin
nico12
Dec 31, 2015 04:42 PM
IainRS1700T
Sep 25, 2015 06:44 AM
beller
Sep 21, 2015 04:13 AM
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
