Trouble with setting Co - Cosworth
Old Apr 26, 2012 | 05:39 PM
Mungus's Avatar
Mungus
Default Trouble with setting Co - Cosworth
Evening all,
Took my Cossie for a pre MOT, most keen to see what the emissions are like!!
8% Co at idle!!
Didnt suprise me as the plugs have been black and the gaps were at 0.5mm - ive since set them to 0.65
So having read lots about Co's and fuel pressures, I went about dropping the Co down to a sensible rate. The setting screw by turning it anti clockwise dropped it down, but just to 3.5% - it would not drop any lower (ideally looking for 2.5%).
Its going to be setup next month, but I worried myself into thinking there maybe a problem with my ECU and I dont want to travel to a tuner only to find that out there and then!! Game over.
I did take the top off the ecu and checked/confirmed that the adjuster had contact with the gubbins inside.
Any ideas guys?? Chip is NMS for T34 and greys.
Huw
Old Apr 26, 2012 | 08:02 PM
andycos's Avatar
andycos
Had the same problem as you with my stage 1 sapphire,and tried the same things as you.
My problem turned out to be the map sensor on its way out,once changed it was back to normal again
In my case the car was running perfect still,but i had only just got it back out of storage so hadnt done many miles.
Old Apr 26, 2012 | 09:01 PM
Mungus's Avatar
Mungus
Thanks for your reply - getting the fuel pressure checked tomorrow as I have a possible theory.....
Out of interest, is there a min/max number of times that Co screw will turn before reaching a stopper?
I have logged all changes to return if necessary but the Co screw seemed to just turn and turn. It went 4 full revolutions until it reached 3.5% Co, but didnt go below that. Doesnt seem right to be so have returned as it was.
Is there an electrical test you can do on the map sensor - I would like to rule that out.
Huw
Old Apr 26, 2012 | 09:06 PM
JamesH's Avatar
JamesH
I hope you marked the CO screw first?
Ring NMS
Old Apr 26, 2012 | 09:11 PM
Mungus's Avatar
Mungus
Ring NMS
Owww yes!
Yeah will ring in the morning as im due up there next month - as I said, just didnt want to go all that way and have a knackered ecu
Old Apr 26, 2012 | 09:20 PM
andycos's Avatar
andycos
Have a look at this old thread about setting the co mixture
https://passionford.com/forum/ford-s...g-idle-co.html
Old Apr 26, 2012 | 10:48 PM
Karl's Avatar
Karl
Norris Motorsport
Hi Huw,
I map all my greys cars to idle around 4 - 5% CO. If your car is just running an off the shelf chip or one from another car, then it will only achieve that CO level if the engine is pulling at least -0.65bar at idle. If it is pulling less vacuum then it will be richer at idle than that.
I do not run greys car leaner than that at idle, because the spray pattern of a grey is very poor and due to the variation in idle fueling caused by heat soak and hot restart, a greys YB mapped leaner than 4 - 5% CO will at times idle poorly.
Old Apr 27, 2012 | 07:26 AM
Mungus's Avatar
Mungus
Originally Posted by Karl
Hi Huw,
Morning Karl,
Thanks very much for that - I think I will leave it till I see you on 17th May
Its one of your chips
BTW - how would I fare MOT time with idle co @ 4%?
Old Apr 27, 2012 | 10:34 PM
martysmartie's Avatar
martysmartie
Be careful as well playing around with the "Global mod" as it's called, aka co screw as it subtracts a percentage from the fuel table so you can end up with it running lean up the top end etc, it's worth getting your AFR checked etc to be on the safe side IMO.
Martin
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
