idle problems
hi there this is my first post on here,i have a 57reg focus st2 with stage 3 mods,whats happening is the idle takes a few moments to settle after revving the engine,the rev counter needle jumps about then it will settle and idle ok,this all started after a garage fitted some rs injectors,i have taken the lower inlet off and can not find any cracks and sprayed brake and clutch cleaner everywhere when running the car,i have no fault codes either,it really is annoying,has anyone got any ideas before i have to take it to a garage,thanks mark.
the rs injectors were fitted as part of an upgrade with bluefin stage 3+,which superchips have said the map will run them with no problems,old injectors 375 i think,rs ones 440,
Well, call superchips then. It obviously is NOT running these injectors without problems.
If the bluefin update is for the original injectors, then refit them.
If I read this the original injectors should be used: http://www.mybluefin.co.uk/search?ma...2&variant=2025
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
