tc and abs question st170
Old Apr 25, 2012 | 07:16 PM
st170danny's Avatar
st170danny
Red face tc and abs question st170
hi can i remove the fuse to get rid of tc without getting rid of abs that is if it is as simple as removing a fuse also how do i no if my st 170 has esp should there be a button for it or is it built in to the tc ???
Old Apr 25, 2012 | 07:27 PM
GVK.'s Avatar
GVK.
ESP was option on ST170, been ages since I've worked on one so can't think where the button is, or indeed if it has one. If it has one I guess it will be in centre console somewhere.
Cars with ESP usually have 6 valves on the ABS hydraulic unit, rather than 4 for ABS - Doubt you can see the ABS pump easily enough to count them.
Unless there is a TC switch,can't disable TC and not ABS,easily.
Old Apr 25, 2012 | 07:30 PM
st170danny's Avatar
st170danny
Cars with ESP have 6 valves on the ABS hydraulic unit, rather than 4 for ABS - Doubt you can see the ABS pump easily enough to count them.
Can't disable TC and not ABS. (easily)
ok thanks for your knowledge mate . so its not as easy as pulling a fuse then or fitting an inline switch to the fuse . thanks
Old Apr 25, 2012 | 07:42 PM
deano2690's Avatar
deano2690
the traction control is turned off by the switch near the gear stick with the wheel on it, so there is no need to pull fuses out lol
cant help you with the esp as mine hasnt got it.
Old Apr 25, 2012 | 08:01 PM
GVK.'s Avatar
GVK.
Yep -If there's a button with a wheel spinning gravel on in centre console, that disables the TC.
Be careful pulling out ABS fuses as the modern cars use the ABS for the brake distribution (brake bias) I nearly wrote off a mate's VR6 turbo Golf at Snetterton a few years back as he had pulled the ABS fuses and the rear end locked up when I stood on the brakes from 140mph
Old Apr 25, 2012 | 08:12 PM
st170danny's Avatar
st170danny
hi yes i no that lol but it still cuts in a bit it never seems to e 100% off iv heard even if the button is off it only turns off wen doing over 20mph . and i think its limiting the power slightly buy cutting in when i boot it it feels like something is holding it back sometimes . thanks
Old Apr 25, 2012 | 08:19 PM
GVK.'s Avatar
GVK.
Pretty sure the ST170 has 'torque limiter' in lower gears which is controlled by the ECU software.
Old Apr 25, 2012 | 08:24 PM
GVK.'s Avatar
GVK.
LOL- I searched on Google and found this thread.
https://passionford.com/forum/ford-f...ml#post5808426
Old Apr 25, 2012 | 08:40 PM
st170danny's Avatar
st170danny
yer i no there is a torque limiter in first and second witch i cant do any thing about but its traction control that i want to stop from kicking in isnt tc done buy the brakes not a torque limiter ??? cheers
Old Apr 25, 2012 | 09:20 PM
GVK.'s Avatar
GVK.
The anti-lock control - traction control is an expanded version of the anti-lock brake system (ABS). The system is integrated with the ABS and uses the same wheel speed sensors and a similar hydraulic control unit (HCU).
The hydraulic control unit has additional internal solenoid valves incorporated to enable control modulation of the wheel brake pressures.
The traction control system reduces spinning of the driving wheels; this can be achieved as a result of intervention through the engine management system and/or the brake.
Two traction control systems are available: brake traction control system (BTCS) for 1.4L and diesel engines, and full speed traction control (TCS) for 1.6L, 1.8L and 2.0L engines.
At speeds above 40km/h, only large amounts of wheel slip is controlled by the brake function (ie aquaplaning).
In order to avoid possible increased wear to the braking system, the ABS/TCS and BTCS systems calculate the brake pad temperature and if it becomes to high brake intervention is switched off until such times that the temperature has been reduced.
Brake Traction Control System (BTCS)
This system minimizes wheel slip on the driven axle to enhance traction at lower speeds and is achieved by controlled braking of the spinning driving wheel, when the grip at the driven wheels are different. It is an integral function of the ABS and cannot be switched off.
The BTCS system is only active at road speeds up to 85 km/h (53 mph). When the system is active the driver is made aware of the fact by the illumination of a warning indicator located in the instrument cluster.
The spinning wheel is braked by the ABS system.
This transfers a greater proportion of the engine torque through the differential to the other driven wheel, thereby increasing the utilization of the available traction control works at all speeds below 50 km/h.
Full Speed Traction Control (TCS)
This system controls wheel slip on the driven axle by a combination of engine torque reduction and brake control to enhance vehicle stability, steerability and traction at all vehicle speeds. The TCS function can be switched off and is controlled by a switch in the floor console.
If the ABS/TCS module registers that the driving wheels are spinning, the EEC V Powertrain Control Module (PCM) can be requested to reduce the engine torque via the standard corporate protocol (SCP) bus (ISO 9141.Ford).
The ABS/TCS module calculates the required engine torque during traction control and sends this request to the EEC V PCM.
The EEC V PCM then calculates the required ignition timing and the number of fuel injectors to be deactivated in order to achieve the required engine torque.
The advantage of the TCS system over the BTCS system are as follows:
reduce load on the braking system
reduced load on the powertrain
improved directional stability
improved steering
shorter reaction time
operates at all vehicle speeds
ST170 runs Black Oak ECU/PCM not EEC V but there is no more info on those that I can see.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
