what else do i need? st200 uim/lower uim, throttle body
my st200 gear as just arrived for my st24,
st200 upper inlet, lower inlet with green injectors and throttle body,
also got a st200 maf,
is there anything else i need??
which throttle cable should i use?
did you get throttle cable with it if you did use that one everything else. looks ok .you mite have to get the car remaps and set up for the green injectors . good luck mate
In addition to those bits the 200 also had different cams, and a slightly different airbox with an extra inlet (just drill your airbox instead!). Different map too obviously.
mk3ste
Oct 17, 2021 10:09 AM
