Eibach Pro Hubcentric BMW E46 25mm Alloy Wheel Spacers
Pair of Eibach Pro Hubcentric BMW E46 25mm Alloy Wheel Spacers & Bolts
Cost £120 on ebay
Want £70
Can post anywhere in uk
Any questions please feel free to ring or txt on
07429 450780
This kit contains 2 spacers
Each spacer is 25mm wide
Total track widening: 50mm
These spacers are hubcentric
Product info
*Made from high-tensile-strength aluminum alloy (as known from the aircraft industry)
*Significant weight advantage compared to wheel-spacers made from steel
*Exact fitment by using minimal production tolerances, resulting in exceptional wheel balance
*High-grade corrosion protection through a special coating process (salt spray test acc. to DIN 50021)
*All applications tested in rigid durability- and fatigue tests
*Available for most popular car models
*Quality approved acc. To ISO/TS 16949
*TUV tested
Cost £120 on ebay
Want £70
07429 450780
Product info
*TUV tested
JK12
33
Apr 26, 2021 12:09 PM
GTR_STU
Aug 28, 2015 01:02 PM
