Engine transplant help
Old Apr 22, 2012 | 05:10 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
Default Engine transplant help
Guys Im currently stripping my series 2 ready for the body shop, now im thinking of putting the engine into my sport until the work is done on the s2.
I started taking the loom out and it looks as if it has to come complete as an entire loom, is this true??
Will i need to transfer the whole loom over or is there an easier way of getting it all running??
Old Apr 22, 2012 | 06:42 PM
studabear's Avatar
studabear
full loom i'm afraid.
Old Apr 22, 2012 | 06:46 PM
johnnysash's Avatar
johnnysash
Yes the loom is attached to the main car loom. You could buy a loom from ebay and butcher it so it only has the engine management parts on it.
Old Apr 22, 2012 | 09:38 PM
Jamie_EscortSport
whole load of heartache then i guess!
i might have a look at it tomorrow and see how difficult it will be to separate the two bits
Old Apr 27, 2012 | 11:38 AM
Lennon's Avatar
Lennon
when i converted my 3i from a series 2 i just unplugged everything from the loom in the turbo and threaded it out of the car via the fuse box hole (thread it into the engine bay) took half an hour or so with a mate helping to feed it through but worked fine for us, same method fitting it back into the 3i. i wouldnt cut the loom about if you can avoid it mate.
also rewiring it isnt as hard as it looks, we just took time to label where each plug went and take photos etc. hope this helps
Old Apr 28, 2012 | 03:11 PM
Jamie_EscortSport
ok mate sweet. ill just bite the bullet and strip both over a weekend
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
