st tdci hesitating
Old Apr 22, 2012 | 05:04 PM
richbogle's Avatar
richbogle
Default st tdci hesitating
Hi,iv got a mondeo st tdci 06 plate, its started hesitating wen ur just driving along,then stick foot down,it kinda chugs like diesel stervation,then goes.seems to b lower down the rev range. Worse i think when cold. No management light or anything. Any help would be apreciated thanx
Old Apr 22, 2012 | 05:30 PM
cossie.con's Avatar
cossie.con
Have it read with a decent machine although there is no light on there may be some underlying issue
Mik
Old Apr 22, 2012 | 05:47 PM
gouch1's Avatar
gouch1
as above best to get it read but id check for leaks from intercooler ect many things can casue the problem leaks pump injectors electronic actuator if it has one although it needs to be properly diagnosed
Old Apr 22, 2012 | 06:19 PM
sicosnutter's Avatar
sicosnutter
had this on my fiesta 1.4 tdci did the water drain off on the fuel filter and its been fine since.
Old Apr 22, 2012 | 07:57 PM
Cosnada's Avatar
Cosnada
Take off engine cover, remove main EGR cold fee hose from intercooler. I bet you have an inch long split just under the EGR valve...........
Old Apr 22, 2012 | 09:18 PM
richbogle's Avatar
richbogle
Drained fuel filter last week,filters not that old. And iv alredy changed the intercooler hose due to it being split. It was modus diagnostic i plugd in and hee haw....
Old Apr 22, 2012 | 09:21 PM
GVK.'s Avatar
GVK.
^^ Exactly that, mostly!
Old Jun 1, 2012 | 06:31 PM
phil-st's Avatar
phil-st
have u checked ur egr valve may need a clean out or cap it off
Old Jun 4, 2012 | 10:35 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Or the EGR is faulty! Check the hose again, they can fail VERY quickly if you used a standard hose.
mark94
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
talon1
Sep 15, 2015 10:27 AM
