Cosworth Amal Valves.....
Old Apr 21, 2012 | 08:44 PM
Mungus's Avatar
Mungus
Default Cosworth Amal Valves.....
Evening all,
Took the cossie for a little run earlier and noticed before I left a load of clicking under the bonnet.
Turns out to be the amal valve - having a fit by all accounts
Have disconnected it for the moment to conduct some tests, look for breaks in the wire etc.
Spec of my car is t34 on greys, NMS chip, RS500 intercooler etc etc
Questions are:
1. Do people still run an amal valve - or have they gone to a boost controller? I seem to have MASSIVE preload on my -34 - its almost taken up all of the adjustment on the rod - yet only peaks about 20 psi??
Now if im correct in saying, there shouldnt need to be all this preload as this can damage the actuator??
I know tuners used to increase the size of the jets to do this but im thinking a boost controller is a more precise way of controlling the boost??
2. When I was doing a little tidying under the bonnet, I noticed that the amal had been relocated from the top of the intercooler to the n/s bulkhead, lengthening the pipework to do it??? Would the change in pipework have an effect on the operation of an amal valve when working correctly??
3. What could be causing the intermittent clicking at the amal valve?
I do have the car booked in soon with Karl at NMS - but would like to get a few diggly problems sorted first .
All help appriciated.
Huw
Old Apr 21, 2012 | 09:54 PM
Paul500+'s Avatar
Paul500+
a good electronic boost controller would work well better then a manual controller
from past exspereance would say that electronic controllers are more stable
as for the preload on the actuator would say a leak some where or a worn actuator
im holding 26psi on a -31 and peaking 33
Old Apr 21, 2012 | 10:05 PM
GVK.'s Avatar
GVK.
Sounds like earth wire on Amal valve may be chafed/shorting to ground and activating the valve? Check wiring back to ECU.
Old Apr 21, 2012 | 10:15 PM
KSA-Cossie's Avatar
KSA-Cossie
If the Amal valve is shafted, I have a spare you. An have foc
Old Apr 22, 2012 | 07:09 AM
Mungus's Avatar
Mungus
Thanks for the replys lads
Thanks buddy - thats much appriciated.
Could I take you up on that please? Do you want any money for postage?
Huw
Old Apr 22, 2012 | 07:12 AM
Mungus's Avatar
Mungus
Any idea on what pin on the ECU? Take it by ECU, we are referring to the coupling to the ECU??
Huw
Old Apr 22, 2012 | 07:35 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
pin 16
black red on the amul valve is battery voltage and is supplied from the fuel pump relay
l1 and l6 activate the amal valve when you key on and the fuel pump is active
the connectors on the valve go dicky as do the valves
if your going to karls why don't you just ask him to fix it will probably only take him 10 minutes
Old Apr 22, 2012 | 07:47 AM
Mungus's Avatar
Mungus
Originally Posted by Turbosystems
pin 16
Thank you for that.
No doubt Karl will be able to sort but I thought id attempt to resolve a few issues before presenting.... and learn a little bit on the way
Huw
Old Apr 22, 2012 | 09:37 AM
KSA-Cossie's Avatar
KSA-Cossie
Huw
No, just pm me your address and I'll stick it in the post mate
Old Apr 22, 2012 | 11:32 AM
Mungus's Avatar
Mungus
You have PM!
Very greatful for that bud....
Took the amal off, got voltage when shes running rather than ignition - prob relating to a fuel wiring mod?? Amal knackered then.
Was only running one restrictor too...
Have now taken the preload off and set it to half moon
Huw
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
