HELP!! cossie erratic ideling HELP lol
Old Apr 21, 2012 | 04:55 PM
escoskmv's Avatar
escoskmv
Default HELP!! cossie erratic ideling HELP lol
when i start my car from cold it ticks over like a pile of shite, as if some one is revin it up, ive changed the idle controle valve with no joy, ive changed the blue water temp sns an still the same allthow it was a spare used sensor i tried. when it has warmed up it ticks over fine drives fine its just on cold start!!! can any one help?????
Old Apr 21, 2012 | 06:04 PM
martysmartie's Avatar
martysmartie
I have had this with mine ever since I had the car, in my case I am sure it's the ISCV, I did try another Ebay job which stopped the hunting but it idled way to fast, it's to do with the incorrect spring rating and you have to sod about changing them around etc with the ones from the other valve.
In your case, I suggest you look toward your TPS, check the output!
Also is your base idle set correctly?
I assume it's the Escos in your siggy?
Martin
Old Apr 21, 2012 | 06:10 PM
MannheimAlex's Avatar
MannheimAlex
If you unplug the iscv are there any changes in the idleing?
Old Apr 21, 2012 | 06:28 PM
Nick.W's Avatar
Nick.W
Reset base idle, Co too lean, tps fault?
Old Apr 21, 2012 | 06:32 PM
escoskmv's Avatar
escoskmv
yes mate it is the escos in my sig but its home built and runs 2wd runnin gear so l6 ecu. it was fine all lastyear an now just started to play up. if i unplug the idle controle valve it ticks over sweet. wot is the iscv lol
Old Apr 21, 2012 | 06:35 PM
MannheimAlex
it is the idle speed control valve
Idle is ok even when the engine is cold?
Old Apr 21, 2012 | 06:44 PM
escoskmv's Avatar
escoskmv
if i unplug the iscv it runns fine when pluged back in its crap againe, i have tried another valve i had spair an that was the same????
Old Apr 21, 2012 | 06:47 PM
RS500/364's Avatar
RS500/364
You have just answered your question !
clean it easy as !
Old Apr 21, 2012 | 06:53 PM
cossie891's Avatar
cossie891
I thought the ISCV is the Idle Speed Compensation Valve NOT control
MannheimAlex
If you tried 2 valves and both where the same I guess the iscv is OK and some sensor is giving the iscv the wrong signals.
Old Apr 23, 2012 | 12:21 PM
martysmartie
The official name is CONTROL valve, however some people like Stu from MSD etc prefer to call it compensation as that's what it's really doing, i.e. giving air compensation over the base idle in the Cosworth's case, whatever the name, IACV etc it's the same component to all intents and purposes.
To the OP now we know that, did you swap the loom/TPS? I suspect you haven't or you have the correct TPS, but haven't changed the loom or modified the existing one by inverting the two TPS wires.
Can you answer YES to BOTH the above questions? If not this will be your problem and the car won't run right period.
The fact when you unplug the ISCV and the revs ease show the valve to be doing it's job!
Martin
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
Fudgey
21
Sep 30, 2015 06:19 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
