AP Racing 4 Pot Brake Pads
Old 20-04-2012, 12:45 PM
hutchie_rs
hutchie_rs's Avatar
Default AP Racing 4 Pot Brake Pads
Im having trouble getting a new set of brake pads. Ive tried a couple of part companies locally by taking the pads in and had no joy. Also on the net ive tried searching but none seem to have the same measurements as the pads I need. They are AP Racing 4 Pots, I think they are from a Sierra Cosworth originally but fitting them to my mk5 escort.
The measurements are : Length: 105mm and Heigth: 57mm. Its the pad type with one lug on the top rather than one at each side.
If anyone knows the part number that would be a good help.
Old 20-04-2012, 01:22 PM
duncans90
duncans90's Avatar
What you need to do is find out the caliper spec numbers, for example my 4 pots are cp5200's. Once you have this number getting the correct pads should be easy
Old 20-04-2012, 01:32 PM
hutchie_rs
hutchie_rs's Avatar
Ok thanks for that, going to work on the car now, will see what I can find. Do AP Racing only do the pads at the correct size or have you found other aftermarket companies do the same?
Old 20-04-2012, 01:40 PM
The Youth.
The Youth.'s Avatar
loads of companies do pads for ap calipers as said above get the caliper part number and it's easy
steve
timsrs
13-11-2018 11:48 AM
yatta
21-05-2016 10:31 PM
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: AP Racing 4 Pot Brake Pads
