Weird Tyre Problem
Old Apr 19, 2012 | 09:08 AM
Jasoncmor's Avatar
Jasoncmor
Default Weird Tyre Problem
Hi all.
I have a weird problem with one of my tyres.
I came out from work about 2 weeks ago to find my FNS tyre completely flat. I thought it was weird, because I drove to work that morning and it was completely fine, no problems, then when I got out, it was completely flat, So I initially thought someone had let my tyre down. So changed it, and went home. Then when I got home, I reinflated the tyre and left it for a week to see what would happen, nothing happened to it and it stay inflated at the exact same air pressure I left it at. So I refitted it to my car and left it for a day, without using my car and it was still fine, so I started using it and driving around and I've been driving around for 5 days I think now, I had no problems whatsoever, I put the hub cap back on, cabletied it and put my jack, spare wheel away. Went out last night, then came to it this morning and it was completely flat again, flatter than it was last time because the tyre has been squished and won't retreat.
Until this happened this morning, I was sure someone had let my tyre down, but now I'm unsure. Anyone know what this is?
Old Apr 19, 2012 | 09:36 AM
_SpeedX_'s Avatar
_SpeedX_
is the rim and tyre sealing togther? i had a similar issue and is was due to slight rust on the rim and was slowly leaking air out under weight of car)
Old Apr 19, 2012 | 09:39 AM
St3V3_C's Avatar
St3V3_C
Yea, you've got a leak somewhere that is only present when the car weight is on the right part of the tyre.
Old Apr 19, 2012 | 09:40 AM
Jasoncmor's Avatar
Jasoncmor
Thanks for your replies.
So is it the tyre or the rim? I dont think there is any rust on the rim.
Jason
Old Apr 19, 2012 | 01:03 PM
SaphCos4x4_Dan's Avatar
SaphCos4x4_Dan
loves a good ham shank
Is it possible when you cable tied the hub cap on it has bent the valve slightly and air is leaking between the valve and rim? Or like above a puncture only leaking with load on the tyre
Old Apr 19, 2012 | 01:06 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
You need to clean the well of the wheel where the tyre's bead sits.
Old Apr 19, 2012 | 01:08 PM
Jasoncmor's Avatar
Jasoncmor
No, the cable tie isn't anywhere near the valve.
Ill try and give it a clean.
Cheers.
Old Apr 20, 2012 | 11:28 AM
_SpeedX_'s Avatar
_SpeedX_
if you go to a tyre place they can skim the rust off and clean it up, i think they did it for free or for a "drink"
i couldnt see the rust as it was underneath where the tyre sits on rim if tht makes sense.
Old Apr 20, 2012 | 04:44 PM
v man's Avatar
v man
Zee Germans are coming
i had a flat the other week but it was only flat at the bottom
the top was completely fine
just cant work it out,,,,,,,,
Old Apr 20, 2012 | 05:09 PM
WongRS's Avatar
WongRS
Definitely sounds like a rim/seal issue to me.
Old Apr 20, 2012 | 05:50 PM
Jasoncmor's Avatar
Jasoncmor
Funny kid
Cheers for all your replies.
Ill take the rim to a garage to have a look at
Old Apr 21, 2012 | 09:33 AM
LHD220Turbo's Avatar
LHD220Turbo
get a tyre place to remove & refit the tyre using some bead seal
mondeomark
Alloy wheels and ICE for sale
Sep 27, 2015 09:17 AM
normink
Wheels and Tyres
Sep 15, 2015 11:25 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Mark RS
Sep 10, 2015 07:27 PM
3dr cossie
Sep 2, 2015 08:58 PM
